Front turn signals not working
Old Mar 20, 2023 | 06:16 PM
ryanuc5's Avatar
ryanuc5
Cruising
Default Front turn signals not working
Hey y’all, just bought a clean 2000. Both front turn signals don’t work. Parking lights do. Rear signals work and do NOT hyper flash. Any ideas??
Thanks.
Old Mar 20, 2023 | 06:20 PM
redzg's Avatar
redzg
Try cycling the flasher several times, and then checking the turn signals. Far, far too common a problem for a part that is rather a significant pain to replace.
Old Mar 20, 2023 | 06:37 PM
ryanuc5's Avatar
ryanuc5
Cruising
Just did that… now the switch is being temperamental… only comes on now at one specific contact point if I hold it down, and only blinks a couple times. Still nothing in the front. To clarify, neither hazards nor signals work in front.
Old Mar 20, 2023 | 07:13 PM
ryanuc5's Avatar
ryanuc5
Cruising
Just realized something else… hazards now work only if I have one of the directional blinkers on. Still nothing in the front.
Old Mar 20, 2023 | 07:27 PM
grinder11's Avatar
grinder11
You probably need a new 4 way flasher, and may need a new multifunction switch. Both are far more difficult to replace than they should be. IDK WHAT GM was thinking when this design crossed the chief electrical engineers desk...
Old Mar 20, 2023 | 11:48 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Try replacing the hazard switch first. Kinda painful to do but the switch is only ~$25 IIRC
Old Mar 21, 2023 | 06:50 AM
redzg's Avatar
redzg
JDM called it. Bear in mind that the ever popular’18 minute’ method is a great way to break the flasher mounting tabs in the dash center vent.
https://www.rockauto.com/en/catalog/...ng+switch,4468
Old Mar 29, 2023 | 07:54 PM
ryanuc5's Avatar
ryanuc5
Cruising
Update… changed both the multi-function switch and the hazard switch… not fixed… fml… any other ideas?
BTW does GM not make parts for these anymore ?!?
Old Mar 30, 2023 | 04:14 AM
LWSZ06's Avatar
LWSZ06
Do your Daytime Running Lights work?
Larry
Old Mar 30, 2023 | 09:08 AM
ryanuc5's Avatar
ryanuc5
Cruising
guessing you mean the fogs (one click on the multi switch). Yes those do work. Just the signals don’t
To Front turn signals not working
