hood buldge driver side
I appreciate any help!
You were in a front end collision which means that lots of kinetic energy was instantaneously dispersed and absorbed. One really has no idea what was effected in the hit on the car. The fact that bash bar had to be moved an inch (a lot but doable) tells me you had a good schwack.
To check your hood, remove the hood and place it on a smooth, level surface. If the four points touch with uniformity, your hood is good and you have another issue. If the hood touches in 3 places and rocks, you hood is warped (damaged) and needs repair. Buying and painting a new one might be easier.
If your hood is good, do some checking on the fender as that may have drooped a bit from the hit. In one photo is look like the corner of the hood is damaged and the front nose cone is missing along with the head light cover? That kind of hit will warp a hood.
It might have warped if it was pushed back at the front corner popping the center up and then left like that for some time. SMC doesn't bend when it takes a hit, it gives until it can't anymore then it starts to break.
