[Electrical] 3-Stage Taillight Sequencer Wiring
I have a (cheap) 3-stage taillight sequencer that's made for 3-stage LED taillight swaps (classic Mustang reno, etc.). There's three wires (besides ground), and each one corresponds to the three steps in the lighting sequence. To translate this to the C5's (effectively) 2-stage LED taillight, I'd like to light the inner light, the inner+outer light, then the outer light (the three stages).
It's obvious to me that the first stage wire needs to go to the inner light, and the third stage wire needs to go to the outer light, but my dumbass can't figure out how to wire the second stage without it interfering with the other stages as well. It's obviously not as simple as connecting the second stage wire to both lights, as that would cause both lights to illuminate for all three stages.
I know a diode could work, but I'm not sure how common diodes are in automotive applications, and I wouldn't know how to size it anyway. I think there might be a way to use automotive SPST relays, but I haven't quite been able to figure that one out.
Any help would be appreciated! I'm hoping there's some veterans on here who think this is ezpz.
Diagram inline, for what it's worth.
Thank you!
he's currently building me a sequencer harness that flashes the way modern sequentials work, all on together -> inner off -> outer off
similar to c8 and mach-e
https://www.amazon.com/SYUAB-Switch-.../dp/B09P3KBS6H
https://fiperformance.com/products/c...fi-performance
If you are going to use these timers, be sure to limit the input voltage to about 12.5VDC MAX.
Most vehicles today have a 14.6VDC regulator and will burn these up. Use a regulator or series diodes.
I use 4ea 1amp silicon diodes in series with the 12V positive lead to drop 2.8VDC to the timer. I have used these timers
on my Z06 DRL white switchover circuits for years with good service, AFTER, I wasted about 20 due to over voltage.
Most all cheap Chinese LED bulbs I have tried are limited to 12.5VDC Max. If you over voltage them, they will start
to blink randomly, then die.
Teeter477
How does your 3 stage sequencer work, Is it Stage 1 = Light 1 On, Stage 2 = Light 2 On, Stage 3 = Light 3 On Or is
it Stage 1 = Light 1 On, Stage 2 = Light 1 and 2 On, Stage 3 = Light 1 and 2 and 3 On ??
If it is the first scenario, it would be easy to get your desired results. BUT, not sure how the Brake Lights will effect the operation??
Both the Brake Lights and the Turn Signals use the same high wattage filaments of the bulbs.
Larry
Would need three diodes capable of 12-15 Vdc and probably about 25mA or so. I do not know what the current draw is for your LED tail lights, but have to match it to the diodes. And be sure to double the individual LED tail light current draw for when both are on. But only need that diode for the stage 2 output.
Just a thought, maybe something to try, diodes are cheap.
I have some diodes in my parts box....may have to find this cheap sequencer and give it a try.
