Cold AC at Idle, but outlet temp warms while driving
Old Mar 24, 2023 | 03:43 PM
Markmbaha1's Avatar
Markmbaha1
Default Cold AC at Idle, but outlet temp warms while driving
I can't find anything on this subject. My 2002 climate control AC today is blowing cold at idle, but warms up while driving. First time I ever noticed this. Its about 78° sunny today, very low humidity. It's almost like the belt is slipping while driving not engaging the clutch. But come to a stop light and it's cold again. There is no belt burning smell, there is no squeeling noise. Could it be low on Freon? Any other thoughts? Thank you.
Old Mar 24, 2023 | 06:23 PM
Markmbaha1's Avatar
Markmbaha1
Originally Posted by C5 Diag
Could be low on refrigerant or maybe the AC clutch is faulty or maybe even a bad compressor…maybe time to see an AC specialist…no magic bullet here…if you don’t have a scan tool I would check for any stored codes possibly related to the AC system through the DIC.
TY, does the hvac have its own set of codes you can read from the AC LED? Otherwise I can't pull any codes, at all.
Old Mar 24, 2023 | 06:30 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
No the AC LED won’t tell you what codes there are…HVAC codes are either “P” (Powertrain) or “B” (Body)…you can access these codes using the DIC…video below if you’ve never done it…also HVAC codes do not illuminate the check engine light.
Old Mar 24, 2023 | 06:41 PM
Markmbaha1's Avatar
Markmbaha1
Thank you. I checked all those when I got it last June. I'll check again. Thank you.
Old Mar 24, 2023 | 08:57 PM
twostepdon's Avatar
twostepdon
I have a 2002 Avalanche that does that when it is low on refrigerant but C5 Diag advice is a better way to go.
Old Mar 25, 2023 | 01:12 PM
Markmbaha1's Avatar
Markmbaha1
I'm reasonably sure the AC belt was slipping the other day. Today I started and let idol for a few minutes to stabilize and the pressure looks fine. At start up I noticed some chirping from that belt area that went away as it warmed up. The other day I started and went, no warm up and probably hit the gas as I turned onto the main road. If it is slipping I'm thinking punching it at high revs may have slicked the belt while it was cold. Today I atarted and idled for 5 minutes or so, then reved up, drove and punched it, cold throughout.
To Cold AC at Idle, but outlet temp warms while driving
