sun visor lights
Old Mar 25, 2023 | 04:01 PM
cdw's Avatar
cdw
Default sun visor lights
new bulbs and fuses good. i get 7.78 volts at the plug end. tested lights on battery charger, good. won't light up when plugged in. i will never use these visor lights but thought i would just try to get them to work. kinda bugs me a little that they won't work.
used the 6 amp on charger to work. have looked at about a thousand post on these. thanks Denny
forgot to add that the underhood,footwell,and glove box lights work well
Old Mar 26, 2023 | 06:02 PM
cdw's Avatar
cdw
thanks for the reply Jason. it was that little cut off switch. the one that when you close the cover it shuts off the current. it even looks like a cheap switch. i had to hot glue it for it to work. they are oem and i have never used them. it just bugged me that they were not working. thanks again Denny
