Load resistor.
Old Apr 1, 2023 | 06:35 PM
link9a's Avatar
link9a
Default Load resistor.
Hi ... I noticed some companies they add load resistor to the tail light this way ( picture 1 ) is that right or wrong cuz I know the load resistor get very hot so is that the right way to put it ?
because I decided to add a load resistor to my tail light because they don't come with it and l must to put it ( long story) so I add a piece aluminum under the load resistor to be more safe so is that will be okay or no ?
Old Apr 1, 2023 | 08:40 PM
PlanoLeMans's Avatar
PlanoLeMans
You don't need load resistance. Get the hyper flash harness. If you are going to do it, I would not suggest thst you heat sink to plastic.
Old Apr 1, 2023 | 09:20 PM
link9a's Avatar
link9a
Even if you have hyper relay still you need to add load resistor to taillights ...if you're taillight led don't have resister it will case a problem. Sooner or later ..l have hyper relay for years and l get problem with hazard switch because l buy upgrade taillight from Vette light that they don't comes with resistor which case hyper hazard ..lam going to post a video for this problem ... ... Hyper relay it's Not enough if you're taillight don't comes with resistor
To Load resistor.
