"Turkey Baster" question.
Old Apr 2, 2023 | 05:59 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default "Turkey Baster" question.
As I get ready to put the C-5 back on the road, after it's winter hibernation, I'm planning on changing the brake fluid. And as usual, I was planning on using the turkey baster to draw the old fluid from the master cylinder. But lo and behold, when I dug the baster out of the tool box, I found that time had taken it's toll on the "bulb" part of it, and it wouldn't seal tightly to the tube.
No big deal, I thought, I'll just get a new one, and as coincidence would have it, my wife and I went to the grocery store today. Boy, what a shock, the $1.25, plastic basters were nowhere to be found. All they had, was a "high falootin", stainless steel deal, for $10-11. I find that a bit expensive, as well as overkill, as I'm sure that the bulb on this one, will lose it's shape, from the brake fluid, just as quickly as the cheap ones, leaving it just as useless.
Anybody know of a source of the "cheap" ones??
(FWIW, the 'Dollar Store' website lists them for $1.25 each, BUT you have to buy a case of 48!! )
Popular Reply
Apr 2, 2023, 08:05 PM
G_Loc's Avatar
G_Loc
Originally Posted by Hawks10
tuekey basting is for people too lazy to bleed. If you’re bleeding there is absolute no reason to tuekey bast unless you just want to waste fresh fluid
No one has said that it's a replacement for bleeding. You should always get rid of all the old fluid in the master before bleeding.
Old Apr 2, 2023 | 06:33 PM
feeder82's Avatar
feeder82
I use a cheap marinade injector, plastic like a syringe. Too suck out brake fluid. They don't last the brake fluid eats the seals. I got it at a big box store
Old Apr 2, 2023 | 06:46 PM
grinder11's Avatar
grinder11
Flea Markets, if any in your area, sell what you want for $2-$3. Flea Market FTW
Old Apr 2, 2023 | 06:54 PM
feeder82's Avatar
feeder82
Do a proper bleed!!!!!!!
The basters is to suck the dirty fluids out of the reservoirs, so you start your bleed with clean fluid. 🙄
Old Apr 2, 2023 | 06:56 PM
C6_Racer_X's Avatar
C6_Racer_X
Dollar tree usually has them for $1.25 each.
You can also use a marinade syringe. Or if you have a Might-T-Vac hand pump (I use one to vacuum bleed brakes), you can use that with a hose. Even the "topsider" vacuum gizmoes that suck the oil out through the dipstick tube will work.
Old Apr 2, 2023 | 07:18 PM
C6_Racer_X's Avatar
C6_Racer_X
the fluid that will come out of the lines will be dirty and you want flush the lines so I’d rather use slightly dirty fluid to flush the lines than fresh fluid. 😂 come one man. That statement is ridiculous. Turkey basting will never flush the lines.
The turkey baster doesn't flush the lines. It takes the nasty old fluid out of the reservoir first. Then fill the reservoir with fresh fluid. Then bleed/flush the lines until you see clear fresh fluid at every caliper, starting at the furthest away, and working to the cali[per closest to the master cylinder.
Old Apr 2, 2023 | 08:05 PM
G_Loc's Avatar
G_Loc
Old Apr 3, 2023 | 08:32 AM
leadfoot4's Avatar
leadfoot4
Originally Posted by C6_Racer_X
Dollar Tree usually has them for $1.25 each.
Not right now....as I mentioned in my original post, their "website store" will sell me a case of 48, however.
Yeah, I have one of those big "tank-like" extractor pumps, which I could use, but the hose on it isn't all that flexible, which makes it somewhat awkward to use, and I do NOT want brake fluid splashing around. For this particular job, the turkey baster happens to be ideal.
Old Apr 3, 2023 | 04:37 PM
PlanoLeMans's Avatar
PlanoLeMans
This is what I use, a syringe:
Amazon Amazon
Old Apr 3, 2023 | 04:59 PM
ak6960's Avatar
ak6960
Walmart
Old Apr 3, 2023 | 05:51 PM
leadfoot4's Avatar
leadfoot4
TURNS OUT THAT ALL 'DOLLAR TREE' STORES ARE NOT CREATED EQUAL!!
Was out running some errands with my wife, today, and in the same strip mall that the chocolate candy store we went to, was a 'Dollar Tree' store. She suggested that we check out this store, just for grins. Wouldn't you know it, they had some of the basters, at $1.25/ea, so I grabbed three of them.
Old Apr 3, 2023 | 06:38 PM
redzg's Avatar
redzg
Bear in mind that pretty much all synthetic rubbers revert over time -- that 'sticky' feel rubber coated Harbor Freight tools eventual develop. Had a baster in an overhead drawer, brand new, in the package, and it turned over the coarse of a couple of years. Kind of welded itself to the wrapping. Not pleasant.
Old Apr 4, 2023 | 07:38 AM
leadfoot4's Avatar
leadfoot4
Interesting. Maybe I'll try giving them a shot of Armor All, to try and slow the process.
Old Apr 4, 2023 | 10:42 AM
runner140*'s Avatar
runner140*
Amazon.com.......turkey baster...old style from $7.00 to 9.00
Old Apr 4, 2023 | 03:21 PM
jjc508520's Avatar
jjc508520
I used a zip tie to tighten up the seal on my bulb....
Old Apr 4, 2023 | 06:02 PM
leadfoot4's Avatar
leadfoot4
Good idea!
To "Turkey Baster" question.
