Hello, I drive a 2003 Corvette Z06 and I’m having some serious issues. A couple days ago, my car suddenly stopped cranking at all. When you turn the key, you can hear electricity humming but no starter click. All accessories work when turned to On position but all turn off when key is turned to Ignition. I’ve already replaced both the battery and starter and nothing has changed. This is extremely frustrating and my friends and I are genuinely losing our minds over this. Please help.
Bill Curlee is the man, all no crank troubleshooting should start at the TDR, it is called the Theft Deterant Relay, but it is the starter enable relay.
When we were first trying to diagnose the issue, Clutch Switch was one of my first thoughts since the car actually does the same no-crank issue whether the clutch is depressed or not. Thanks for the image and I'll take a look when I get some time.
Kk I’d it was the ignition switch the car would act completely dead I’d check the starter next clutch switch is possible but very rare
Awesome, I'll get a peek at it when I get a chance. I have a multimeter and whatnot, however, I'm not very well versed in working on cars just yet. How exactly would I check the switches? Is there a guide somewhere? Thanks for all the help.
If the car powers up but doesn’t start it’s not the ignition switch. When my ignition switch failed the car acted as if it was dead if focus on the starter
Again, thanks for the tip! My friends and I will take a look tomorrow and see if we can find anything.
