I have 4000$ to spend on upgrading my 99 c5 vert. I wanted to know what do u guys think would be my best bet, if i was looking for the best combo that would shave some time of my 1/4 mile....with out using nitrous... my c5 is auto and stock...Thanx :reddevil
That's $4300 installed for a combo that I have seen go into the 11's. You will probably run between a 13.3 to a 13.8 in your stock vette, with any type of traction you will easily be in the low 12's with that money spent.
Gears and TC is the best bang for the buck. Virtual/SOTP 70+ hp increase.
Since you have 4k, you could also intall a nice cam and do LS1 edit/dyno tune. The stock heads flow pretty well, and with a nice cam many people are seeing 25-35rwhp increase.
I would do a cam shaft package $1695. includes pushrods, springs, oil pump mod, crank bolt, before and after
dyno tuning, LS1 Edit, 160 stat
This will get you about 30-35 RWHP
I assume you have 3:15 gears?
Vortex Ram-air $249.00
Borla Stinger Cat back exhaust $649.00 installed
Do the LS6 exhaust manifolds $495.00 installed
Yank 2800 Torque Conveter 995.00 installed
You should be around 290-295 RWHP now, this combo would put
you around 350 RWHP
We would appreciate the Biz if you decide.
[Modified by 21STCENTURYMUSCLECAR, 7:39 PM 1/15/2003]
thanx for the help guys..i am either going to get the 3.42 gears with 2800 stall.....or vr ram intake + T.P.I.S headers + Corsa exhaust + u.d pulley ......... :reddevil
