Fuse for HUD?
Old Apr 17, 2023 | 09:10 AM
Waterford409's Avatar
Waterford409
Default Fuse for HUD?
In a 2004 C5 what fuse controls HUD?
Old Apr 17, 2023 | 09:57 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Wiring for 2004 below…it receives power from Ignition 1 voltage from IPC…no direct fuse.
Old Apr 17, 2023 | 10:47 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
What issue are you trying to fix? As stated above it isn't a problem with the fuse. You may be suffering from HUD drop. There is also the brightness slider that you can use to turn the off.
Old Apr 17, 2023 | 06:18 PM
Waterford409
Thanks C5 diag for your quick response. The problem started after I took the dash apart to replace the HUD Bezel. My HUD wasn't working also, I found out it wasn't plugged in. I installed a "low mileage" HUD while I had the dash apart and it worked fine when I tested it. The problem is the battery goes dead after setting for a few hrs.
I know some of the electronics will function with the ignition off and the key out, do you know what my amp draw should be under these conditions? I feel a previous owner may have unplugged the HUD when he had the problem I'm experiencing.
Old Apr 17, 2023 | 06:43 PM
C5 Diag's Avatar
C5 Diag
The battery should not go dead after a few hours…completely dead is around 10.5 volts…fully charged is 12.66…normal current draw is around 25 milliamps once all the modules go to sleep.
Old Apr 17, 2023 | 10:13 PM
Waterford409
I'm at 5.4 amps with the key out and the battery goes down to 4-5 volts.
Old Apr 18, 2023 | 03:31 AM
Moved to C5 Tech.
Old Apr 18, 2023 | 07:14 AM
C5 Diag's Avatar
C5 Diag
The big thing is that the more the battery discharges it will considerably shorten its service life…watch the video and with your DVOM you can test each fuse…initially you can remove the B+ cable off your alternator…if you have a bad diode it can cause a parasitic drain…video below !!
Old Apr 18, 2023 | 05:02 PM
Missileboy's Avatar
Missileboy
both fuse boxes have the fuse layout and applicable circuit on a sticker in the fuse box covers. Learn those fuse locations for what is in the engine bay fuse box and passenger footwell fuse box. It will save you a lot of time in the future for quick checks-
Old Apr 19, 2023 | 07:12 AM
Waterford409
The draw is in "Body control module-ignition 1 instrument control panel" fuse 25. as suggested by the fact the HUD was unplugged and the thoughtful drawing sent by C5 diag. I have another switch to try and hopefully I can do the replacement without tearing the complete dash out. Thank you for everyone's input........what a great site.
Old Apr 19, 2023 | 08:36 AM
Waterford409
Can I remove the inst. cluster bezel without tearing the dash apart? I've removed the 2 fasteners but it doesn't want to come off and I don't want to damage any thing while trying to get at the HUD switch.
Old Apr 19, 2023 | 08:41 AM
C5 Diag's Avatar
C5 Diag
Old Apr 19, 2023 | 11:04 AM
Waterford409
Good video on cluster removal. I found this video on youtube
that reminded me that you have to pull the cluster to remove the bezel (screws behind the cluster) so here I go again. Thanks again for your input.
Old Apr 20, 2023 | 11:09 AM
Waterford409
HUD switch replacement solved the problem. Thanks again to all contributors.
To Fuse for HUD?
