Source for Vacuum line ends?
Old Apr 30, 2023 | 02:22 PM
ChrisLSx's Avatar
ChrisLSx
Default Source for Vacuum line ends?
I'm redoing the vacuum lines on my 2004 C5 and I'm in need of some replacement 90 degree rubber ends on the under-hood vacuum lines. I've had bad luck with the Dorman vacuum ends in the past (other vehicles) as they seem to dry-rot VERY quickly (within 6 month to a year). Does anyone have a source for these ends new?
Old May 1, 2023 | 10:05 AM
redzg's Avatar
redzg
Dorman sure seems to make a lot of stuff that is almost good enough. What we need is to find Honda alternate part numbers — always very high quality and stocked for decades longer than GM. Which ends are you specifically looking for — the back of the manifold and the reservoir?
Old May 1, 2023 | 10:55 AM
ChrisLSx's Avatar
ChrisLSx
All of the above, plus the ends that connect at the "T" near the ECU. Basically all of the rubber fittings are dried out (20 years in AZ will do that).
To Source for Vacuum line ends?
