Help help help! Reduce engine power and traction control it’s a 1998 corvette
Old Apr 30, 2023 | 08:09 PM
Miguel Oliveras's Avatar
Miguel Oliveras
5th Gear
Default Help help help! Reduce engine power and traction control it’s a 1998 corvette
Yes I got a c5 1998 and now I can’t use it because she goes on reduced engine power because of traction control problems theres a way that I can bypass the system in order to use it
Code P1516
Old Apr 30, 2023 | 09:08 PM
mmartinez's Avatar
mmartinez
Try disconnecting the battery for 10 minutes or so, if that doesn't work you should remove the passenger wheelwell cover where the PCM and TAC module resides. Pull connectors on TAC module and spray with electronic contact cleaner, also inspect the wiring harness, you might have to replace the TAC module, hope not.
