Cam/Head Combo Advice Requested
I have an 2004 M6 car I recently acquired that was in disrepair [non runner when I bought it] but have now completed phase 2 of the overhaul and she's running, shifting, and most importantly braking now lol I've swapped all the fluids and and now am turning my attention to sprucing up the driveline. At present, it's got 241 heads which from my research are pretty good flowing heads [as most cathedral port heads]. The balance at present has a wobble which is causing the serp belt to chirp at time so it's time for a replacement. I hate doing work twice so since I have to pull the rack, balancer I figured I would mind as well do the cam, timing chain, timing cover, and HV oil pump while I'm in there for piece of mind. So that brings me to my main question...is it worth doing the heads to?Background / Goals:
- I'm mechanically inclined and do my own work. Swapped out plenty of heads and cams in a gen 1 SBC's
- Not looking to set the world on fire, but close to 400 rwhp would be nice.
- 2004 so LS6 intake.
- Keep 241 heads and have them cleaned up with a valve job and milled for a 64cc chamber.
- Texas Speed 228/232 or Torquer V2 <--anyone with real world experience on either of these cams?
- LS7 lifters
- Trunnion kit for stock rockers.
- Replace 241 heads with a rebuilt set of 243s at $750 buck shipped [ebay rebuilder with 6 month warranty]. I wont be porting as I don't wanna spend an additional grand with AI or TSP.
- LS7 lifters
- ProHeader CNC Ported heads - Super suspicious on this one as its 1/2 the cost of PRC or AI CNC heads but the flow numbers look pretty good. This
- LS7 lifters
Cheers,
Joe
Without getting into too much personal opinion, and what I would do in this situation etc etc. My vote would be to cam it, leave the heads alone other than springs. Run it, digest it. Can always do heads later without doing the work twice if you feel you need more power.
I don't have personal experience with those cams, or any cams for LS, but it's a similar cam to one I've had my eye on from Cam Motion called the Track Weapon. I like that cam because it has gobs of torque mid range, can still spin it high, but keeps lift a little lower so can get away with PAC 1218 springs and won't need hardened pushrods. I would expect 380-400 HP on stock heads and the Track Weapon Cam. Maybe a little more with the cams you mention up top, but will need some more valvetrain upgrades.
I guess for me, I'm stuck in my gen 1 SBC processes lol On those heads always have to come off for a cam swap to get lifters. Apparently on the LS's you can still a dowl rod through the front of the block to hold the lifters up and leave heads intact. Heads off though...I could at least inspect lifters and maybe de-carbon tops of pistons. Not that it's necessary...but I have the terrible technicians curse lol I need to see it to know its ok lol
I will take a look at your cam. I was planning on using PAC 1218 or 1219 springs myself with something .600 and below. I personally like my cams and associated hardware to be born together and die together...Although I know with roller rockers that aint required.
Joe
But if you're taking the heads off no matter what anyone says, then I would do option 2 and get the 243 heads. Stock v stock they're good for about 15WHP over 241s. Another option if you don't trust just anybodys rebuild on the heads would be to get AFR Enforcer headsIt will be a few more bucks though. Flow slightly better than 243, use great valvetrain components, and built by a company any SBC-guy will trust.
Option #1
- Will be doing summit balancer, billet double roller timing set, melling HV oil pump, timing cover while I'm there
- LS7 lifters <- Will inspect lifters while its apart and if they look good will run them...but kinda leaning towards just slapping new boys in there. We shall see.
- Speed Engineering and X pipe
Cheers Boys...and thanks for the suggestions,
Joe
I'm doing all the fun stuff before I deal with clutch and sending unit
Got the wonky fuel gauge blues. it's an 04 so yeah...im tryin EVERYTHING before engauging in rear cradle drop action. Yes I got some Techron in it so I'm waiting to see if that cures my wacky gauge. Clutch feels good but I aint really romp'ed on it yet...and I wanna romp in confidence.
- LS7 lifters
- LS7 lifters
- LS7 lifters
Cheers,
Joe
Joe
EDIT!!!!!!!! There are some ported (by Texas Speed) 243s for sale for $1,400 in C5 parts for sale section......
The AFR's may be the price you said, but I googled the Mongoose ones you listed and it started at 5k a head. Ported 243's for $1,400 is doable though. Can you link me with that listing? I though I did a search and I didnt come up with any recent hits.
As far as the SBC lifters...yes, after the intake is off...on a FRESH MOTOR...you may be able to spin the cam over and grab the lifters from the sides and up and out. Many times [at least in my case] when they get some miles on em and oil changes weren't a priority...they get stuck in the bore. Then it's either vice grip time or the lifter puller thingy-a-ma-bob that grips the inner lip of the lifter. My point was...just easier to remove when the head is off [albeit not required]. When I was wrenching for pay...no way I did a cam without either changing from stock heads to aftermarket, or at least HIGHLY recommending at least taking the heads of to have them checked...if all good and just needing clean up...slap a new FelPro Gasket on and send it. Had one job one time where dude didn't want to pay the labor so I left the heads on and slapped the cam and sent it. Car ran like **** before...but worse afterwards [cam was a rather big one for my taste]. Had to do a leak down test Turns out and wouldn't ya know it...4 burnt valves. So...him fighting me for 2 hours labor...cost him 6 [plus machine shop costs] in the end. Since I do my own work...the only person I can blame a come back on is me lol
Joe
