Help Engine coolant question
Old May 9, 2023 | 05:26 PM
02corvetteboy's Avatar
02corvetteboy
Default Help Engine coolant question
Hey Guys
i need some input from y’all if you got a minute. I see bubbles in my coolant tank? I researched on the forum here, I know it might be a head gasket but let me fill you in on everything. Combustion gas test- negative
Pressure test- holds 16psi for hours
no visible leaks
no white exhaust
car does not overheat
car runs as strong as it ever did
no milky froth in oil
no residue on coolant cap or oil cap
verified coolant cap doesn’t leak
im stumped any ideas?
thanks in advance
im stumped
Old May 9, 2023 | 05:36 PM
Fast one's Avatar
Fast one
It might be steam from the small steel steam vent lines on top of the engine that feed into the top of the radiator.
Old May 9, 2023 | 05:39 PM
02corvetteboy
so is it normal then. I’ve read in other posts where some guys say it normal for a c5? A lot of conflicting info. First time I noticed it and only because I was doing some other none coolant related work?
Old May 9, 2023 | 09:03 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes Sir.
Old May 9, 2023 | 09:27 PM
v8srfun's Avatar
v8srfun
Nothing to be concerned about especially if you just were in the system and it is working all the little trapped air pockets out. But most likely you are seeing the stream of coolant returning back to the tank and it is causing a splash that looks like bubbles.
Old May 10, 2023 | 10:14 AM
grinder11's Avatar
grinder11
Originally Posted by billschroeder5842
Yes Sir.
I agree. Especially since he was recently "in there." However, if bubbles continue for a month or so, pretty much means it's a head gasket, and OP should consider himself lucky it didnt get into the oil, and vice-versa..
Old May 10, 2023 | 11:06 AM
wydopnthrtl's Avatar
wydopnthrtl
Technically the fill bottle is called a "degas bottle".
One of its multiple functions is to use it as the highest spot in the cooling system so as to remove air bubbles that are formed on hot metal parts of the engine. The flow rate is sufficient enough to sweep them off the cylinder walls and around the exhaust valves and suspend them until it reaches the degas bottle.
This makes the fluid going to the engine more dense / less aerated and therefore more efficient for cooling.
Based on what your seeing its likely normal operation. You might consider changing the fluid if its more than 3yrs old.
(I was a OEM water pump engineer in the 90s ;-) )
Old May 10, 2023 | 12:23 PM
c5arlen's Avatar
c5arlen
My personal wrench told me my coolant was needing to be changed which she did adding fresh stuff... How often must it be changed?... GM instructions are wrong... bigtime.
Old May 11, 2023 | 02:21 AM
Moved to C5 Tech.
Old May 13, 2023 | 11:41 AM
grinder11's Avatar
grinder11
4-5 years, MAX. I go 5 years, MAX, on my C5 using dexcool. Older dexcool formulations would coagulate/partially solidify if you never changed it. I don't want to find out if newer formulation does. Change it every 54-60 months, you'll be fine.......
Old May 13, 2023 | 01:56 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Which GM instructions are wrong and how did you determine that?
To Help Engine coolant question
