Electrical Gremlin
Several years ago, all of my lights on my 99 Coupe started to hyper flash when I started the car. If I turned my headlights on, the flashing would stop but my left turn signal indicator would stay on.
My front market/turn signals & tail lights are LED.
I replaced my hyper flash harness and the problem was solved - At least it Was !!
Last weekend, the Hyperflash was back with the exact same symptoms.
Today, I replaced the hylerflash harness (again) which solved the problem - or so I thought.
I drove around the neighborhood with no issues. Then I parked the car so I could give it a good cleaning.
When I started the car, the hyperflash is back. Once again, turning my headlights on will cause it to stop but will keep the left turn indicator illuminated
The only code I have is for the BCM. It’s B2583
From what I can find, the code is for: LEFT FRONT TURN SIGNAL MONITOR CIRCUIT
Any Help/Guidance is Greatly Appreciated !!!!
Thanks in advance…
UPDATE - It’s not doing it every single time I start it. Did it 3-4 times in a row. Then I drove it with the parking lights on to keep the hyperflash from happening. I turned the lights off after a few minutes & the hyper flash didn’t happen. Parked the car & restarted it - the Hyper Flash was back.
then I started & restarted the can numerous times with 50/50 results.
~ I have already replaced the ignition switch.
The fact that replacing components buys you a bit of time also tells me you may have a relay or wiring problem. If it is a relay, swap it. If you have a wiring issue (a faulty wire can miss read electrical current) you either live with it or switch back.
Did you ever rectify the problem?
I just installed Vette Lights tails and front markers and am having all sorts of weird electrical issues: horn honks, TC on/off/on/off, door ajar messages come and go, weird stuff.
