Engine turns over but won't start
Old Jun 5, 2023 | 11:13 AM
Blue Lightening's Avatar
Blue Lightening
Default Engine turns over but won't start
My engine turns over but it won't start. It is as if it is not getting gas. This just happened suddenly. Any ideas?
Old Jun 5, 2023 | 02:01 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Well it comes down to no fuel, spark, or ignition…did you check for any stored trouble codes ??…do you hear the fuel pump turn on for 2 seconds and shut off when you turn the key on ??…also look at the Tach when it cranks…if the Tach does not move (usually reads around 150 RPM) when cranking this may be a bad crank sensor…bad crank sensor will not give you spark and injector pulse.
