Weird pop or clunk sound
Old Jun 12, 2023 | 02:51 PM
NateDiz's Avatar
NateDiz
4th Gear
Default Weird pop or clunk sound
I have a strange pop or clunk sound when turning at like 15-30mph. Never while stopped. Its better described as when momentum is shifting drastically. Almost always happens when turn to the right. Feels and sounds like its coming from under my seat along the frame or something.
Any thoughts are welcome. Thanks
Old Jun 12, 2023 | 10:27 PM
nitromainia's Avatar
nitromainia
Power Steering Rack
Sway-bar Bushings
Sway bar Links
..... Or Aiiens
Old Jun 13, 2023 | 12:48 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Originally Posted by nitromainia
Sway-bar Bushings
Sway bar Links
This is the way to bet. Get under your car and move them about. If you are lucky you can just tighten the end links or at worst you can replace the bushings. Cheap and easy.
Old Jun 13, 2023 | 01:20 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I started getting weird noises also. I lubed all the bushings and anything else I could find. No change. I was afraid it was the differential going wrong. I had changed the fluid after break-in and the manual says that that should be good for a ever. Well I changed the fluid anyway, and the noises have disappeared and it's been a couple of weeks now and not a peep out of it. I hope this helps you out too. The key to your question is that it happens when you are turning. The limited slip differential gives you traction even when one wheel is rolling faster than the other. The diff oil with the additive has properties that allow that to happen.
Old Jun 13, 2023 | 05:48 PM
666lisa's Avatar
666lisa
Get a video if u can. someone might know exactly what it is if we can hear it.
Old Jun 14, 2023 | 12:15 AM
Moved to C5 Tech.
Old Jun 14, 2023 | 08:00 PM
grinder11's Avatar
grinder11
I'd put my $$$$ on the diff/Belleville washers....
To Weird pop or clunk sound
