LSD clutch pack break in
Old Jun 22, 2023 | 10:03 AM
Bobbo76's Avatar
Bobbo76
Veteran: Canadian Forces
Default LSD clutch pack break in
I'm doing a complete rebuild of my C5 diff. Everything inside is being replaced including the clutch pack in the LSD from the conventional disks to the carbon C6 disks.
I'm wondering if anyone has any knowledge or thoughts wrt break in of the disks or just "give 'er"?
Thanks!
Old Jun 26, 2023 | 11:14 PM
MetalMan2's Avatar
MetalMan2
This is what I posted elsewhere on the topic:
My first stop after leaving the garage was a nearby parking lot, where I did 10x figure-8s. These were very tight radius, nearly lock-to-lock on the steering. Hopefully that'll get the rebuilt LSD off to a good start.
For reference, that was after LSD rebuild with C6Z parts. It's been almost 3 years, and 7,400 miles since then and the LSD seems to be fine... granted with pretty much just daily driving on a stock LS6.
In general, I believe the main goal is to ensure good lubrication of all friction surfaces prior to extreme loading. Don't forget to soak the friction plates in new fluid overnight prior to installation!
Old Jun 27, 2023 | 07:24 AM
feeder82's Avatar
feeder82
Here's rpm's guide, good break-in tips
File Type: pdf
Old Jun 27, 2023 | 09:45 AM
Bobbo76's Avatar
Bobbo76
Thanks Gents!
To LSD clutch pack break in
