Turn off TPMS with VXDIAG
Old Jun 23, 2023 | 10:44 AM
Jdrive's Avatar
Jdrive
8th Gear
Default Turn off TPMS with VXDIAG
Has anyone used a VXDIAG Nano GM to turn of the TPMS on an '02 C5? Looking at purchasing one and wanted to make sure it would work like a tech2 for disabling the tire pressure sensor messages.
Old Jun 23, 2023 | 03:18 PM
frodo84's Avatar
frodo84
Uneducated autodidact
I didn't know a TECH2 would turn off the TPMS.
Old Jun 23, 2023 | 03:30 PM
2010Pony's Avatar
2010Pony
My 2000 since I’ve had it reads blank on all sensors don’t know if they were set up when the previous owner put new tires on or not, but I don’t miss them going off like on other vehicles. Maybe I’ll be sorry sometime.
Old Jun 23, 2023 | 03:43 PM
SilverC54me's Avatar
SilverC54me
Only 2001+ can the TPMS sensors be disabled. With the introduction of the Z06 in 2001 GM changed the RFA module to allow the TPMS to be disabled.
Gary
Old Jun 23, 2023 | 04:00 PM
2010Pony's Avatar
2010Pony
Why would all of mine read blank? Just wondering and it’s a 2000
Old Jun 23, 2023 | 04:14 PM
grinder11's Avatar
grinder11
Blank, or xx?
Old Jun 23, 2023 | 06:13 PM
2010Pony's Avatar
2010Pony
I don’t remember will have to check, I know it shows all 4 but no reading
Old Jun 23, 2023 | 06:35 PM
grinder11's Avatar
grinder11
Are you aware of them not working until you're moving? I think it's to save the batteries, but on my 2000 model they read nothing until moving around 5-10mph.
Old Jun 23, 2023 | 06:51 PM
2010Pony's Avatar
2010Pony
Thanks I’ll have to check that this weekend only looked while setting and messing around with it
Old Jun 23, 2023 | 08:29 PM
Jdrive's Avatar
Jdrive
8th Gear
I'm tired of the service tpms message every time i start my car. Probably could get temporary use of a tech2 to disable the tpms monitor but if the VXDIAG Nano would do it I will make the purchase.
Anyone with any experience here?
Old Jun 23, 2023 | 08:33 PM
2010Pony's Avatar
2010Pony
I agree don’t like any of the messages popping up that’s why I never tried to program them with a magnet
Old Jun 24, 2023 | 12:23 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I believe that except for updating the pcm software the vcx nano fully emulates the tech2. So you should be able to remove the tpms system from the bcm as long as your C5 is a 01-04.
Old Jun 24, 2023 | 12:41 PM
grinder11's Avatar
grinder11
The strong magnet works every time! Try getting one from a trans repair shop. They're black, and look like a donut. They come in OEM trans pans to grab metallic particles.
Slip them over the stem, they are strong, and they work great!!
Old Jun 24, 2023 | 02:20 PM
2010Pony's Avatar
2010Pony
Ok just checked my sensors and they are just blank, shows all 4 but no XX nothing, this was not driving just setting still. 2000
Old Jun 24, 2023 | 06:40 PM
jdmvette's Avatar
jdmvette
Night Owl for life
^ wheels need to be turning to register psi
Old Jun 24, 2023 | 08:29 PM
2010Pony's Avatar
2010Pony
Ok thanks, going out tomorrow for a ride
Old Jun 25, 2023 | 07:46 PM
Jdrive's Avatar
Jdrive
8th Gear
thanks C5MSG2004Vert for the info!
Old Jun 25, 2023 | 11:40 PM
dhirocz's Avatar
dhirocz
I used it to turn mine on with tech2win on my Z06, so you should be able to turn them off. However I’d try to fix it first.
I think they need to see rotation to turn them on, or you need to sync them, before they will read.
To Turn off TPMS with VXDIAG
