Adjustment to tune?
Old Jun 25, 2023 | 12:06 PM
black_89_vette's Avatar
black_89_vette
Default Adjustment to tune?
1999 A4
My car has recently underwent a cam swap, diff heads and a tune.
The tune was done by HP Tuners.
Is it possible to read the tune and even edit the tune with another program like Tuner Pro (which my friend uses)?
Looking to see if I can add timing and remove fuel from certain areas, and also raise the shift points.
Old Jun 25, 2023 | 07:44 PM
HardcoreABN's Avatar
HardcoreABN
Not sure, don't know anyone who uses Tuner Pro...Only one way to find out.,..
Old Jun 25, 2023 | 10:13 PM
Supercharged111's Avatar
Supercharged111
As long as you didn't install a custom operating system with HPT, yes. What you should really be doing is upgrading to the newer style PCM and monkeying with that tune.
Old Jun 27, 2023 | 12:36 PM
black_89_vette
Newer style PCM, like from a C6?
Old Jun 27, 2023 | 11:38 PM
Supercharged111
No, either the 512kb or 1024kb 411 PCM as they're called. The C5 used 3 different PCMs in its existence. Did you say whether or not you had emissions testing?
To Adjustment to tune?
