Corvette C5 Year 2000 | Bad harmonic balancer?
Old Jun 29, 2023 | 04:52 AM
unixsan's Avatar
unixsan
7th Gear
Default Corvette C5 Year 2000 | Bad harmonic balancer?
Hey! I was wondering if someone can help me find out whether my harmonic balancer is going bad or already is. I have noticed that there is quite a bit of wobble going on with the belt. I have attached a video.
Old Jun 29, 2023 | 08:27 AM
Ph300zx's Avatar
Ph300zx
Yeah that looks pretty bad, I'd have that high on the list of things to do if you can see it that much!
Old Jun 29, 2023 | 11:41 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
The video is good but tough as what you need is a "side" shot of the engine and focus on the balancer itself. You are looking for the balancer to wobble as you look at it from the side. Head on will tell you nothing.
Also, take some paint and put a line from the inside of the balancer to the outer hub. This cover the metal and the rubber. Drive it a bit and see if the lines separates. If the lines separates, then your hub is shifting and need a replacement.
Old Jun 29, 2023 | 01:25 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Poopy!
Old Jun 29, 2023 | 01:38 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Yup, time for a replacement. Go with a decent aftermarket option rather than OEM. It wouldn't be a bad idea to pin it to the crank if you have plans for any power adders in the future.
Old Jun 29, 2023 | 01:46 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Another vote for replacement! Do it sooner than later, or major problems to be had (oil pan or steering rack)!
Old Jun 29, 2023 | 02:03 PM
Frank4202's Avatar
Frank4202
Thats a bad one. Replace it with something other than AC DELCO unless you want to have the same issue again in a few years.
Old Jun 29, 2023 | 05:00 PM
unixsan's Avatar
unixsan
7th Gear
Thank you all for the fast replies! I have already ordered a new balancer and a bolt for it. Now gotta prepare for the hard work needed to fix it
Old Jun 29, 2023 | 05:03 PM
unixsan's Avatar
unixsan
7th Gear
Will do that asap, while waiting for the new balancer. So I know that it is safe for driving
Old Jun 30, 2023 | 09:56 AM
grinder11's Avatar
grinder11
Curious what brand, and if you went with a UD balancer.....
Old Jun 30, 2023 | 02:57 PM
'Shifter's Avatar
'Shifter
NCM Member '09
If your crank bolt is anything like mine, might want to loosen-up, do some curls, etc....
Old Jun 30, 2023 | 07:18 PM
unixsan's Avatar
unixsan
7th Gear
I just drove for 4 hours and the line did not separate. The only kinda new thing that appeared is a slight squeaking noise coming from the balancer`s area. Nothing more wobbly or unusual tho. Wondering what that could be.
Old Jun 30, 2023 | 07:20 PM
unixsan's Avatar
unixsan
7th Gear
The brand of the balancer is DORMAN (594115 from RockAuto), and I also ordered a new bolt for it.
Old Jun 30, 2023 | 09:44 PM
Moved to C5 Tech.
Old Jul 1, 2023 | 07:10 AM
unixsan's Avatar
unixsan
7th Gear
This is the video showing the new squeaking sound. I am wondering is it the belt or some pulley going bad.
Squeaking sound
Old Jul 1, 2023 | 10:04 AM
Prop Joe's Avatar
Prop Joe
Since you are changing the Balancer already, I'd replace all the belts, tensioners and pulleys. Clean the pulleys grooves that are not being changed with isopropyl alcohol and a brush to remove contaminates. I just bought and installed the Gates both kits on my car. Zero noise/squeaks. Might want to think about a water pump as well since you are that far into it. If nothing else check the weep hole on the bottom WP shaft for signs of leakage.
Main belt kit
https://www.rockauto.com/en/moreinfo...11659&jsn=1046
AC kit
https://www.rockauto.com/en/moreinfo...11659&jsn=1045
I see your in Bulgaria. Do you guys have amazon? Might be less expensive for shipping?
Summit makes good tools to remove and install the Balancer if you cannot procure locally.
Old Jul 1, 2023 | 10:33 AM
unixsan's Avatar
unixsan
7th Gear
Main belt kit
AC kit
Thanks for the suggestions! I actually ordered new pulleys and tensioners, as well as new belts. We dont have amazon, but when I order from RockAuto the shipments come in 3-4 days with DHL. Was very surprised the first time I ordered from rockauto
To Corvette C5 Year 2000 | Bad harmonic balancer?
