Wiring questions
Old Jul 1, 2023 | 06:23 PM
sboblett's Avatar
sboblett
Default Wiring questions
i removed the center that covers the HVAC panel and the radio and there were two loose wired below it that I could not tell where they went. I have attached pictures of both. The three wires in the video file are red, white and copper and I cannot tell about the ones coming from the ignition switch.
I removed the center panel on my 2001 Corvette today and there were two sets of wires loose that I could not tell where they went, the attached are pictures of them. The wire in the center from under the liner has wires of red, white and copper. I cannot tell the colors of the wires coming from the ignition switch. Does anyone have any suggestions? Thanks.
Old Jul 1, 2023 | 07:05 PM
jcgunn's Avatar
jcgunn
Is this a flood car? What is all of that crud? Those wires could be some sort of VATS bypass. Not OEM.
Old Jul 2, 2023 | 06:25 AM
sboblett's Avatar
sboblett
Definitely not a flood car just the old foam disintegrating.
To Wiring questions
