Brake Specialists, please chime in!!!!
Old Jan 19, 2003 | 01:35 AM
Untouchable00's Avatar
Untouchable00
Default Brake Specialists, please chime in!!!!
I know much about drivetrain and engine and all the other good stuff....but I have no idea about brakes. My brakes are just fine, with 22K on them, but I love the look of nice slotted rotors (and drilled, too).
I do not want to spend a million dollars just for the look and a little improvement. What should I do for brakes?? When I swap rptos, what else will I have to swap?? What rotors do you recommend (shoes, pads, etc...)?? I think the stock ones are just fine, so I am more into the brake system I have now, with a better look on the rotors. Please help!!!
Old Jan 19, 2003 | 02:04 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Brake Specialists, please chime in!!!! (Untouchable00)
Get the Eradispeed rotors front and rear with stock pads. If you are into a painted caliper I would say go for it!
vetterdstr :cheers:
Old Jan 19, 2003 | 10:53 AM
CHJ In Virginia's Avatar
CHJ In Virginia
My preference would be the Baer Eradispeeds and a set of the GM ceramic pads. The baer rotors look great and have a zinc wash to keep rust at a minimum. They are a simple swap with on other parts required. The GM ceramic pads are QUIET and almost dust free while still supplying good performance.
Old Jan 19, 2003 | 11:35 AM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
Default Re: Brake Specialists, please chime in!!!! (CHJ In Virginia)
:iagree: Also, look for, or contact, a CF supporting vendor for their next group purchase on these items. I had a chance to get a heck of a deal from MTI last year, but I decided the stopping could wait:D , I wanted to go, so I opted for the MagnaCharger instead. Last week I did install the Raybestos ceramic pads on my car for the decreased dusting.
Old Jan 19, 2003 | 03:42 PM
Gramps's Avatar
Gramps
http://www.electro-dynamics.com/brakes/brakes4.html
Check this out. I am thinking about this set-up because it is not outrageously expensive and it appears that it would be a fun project.
Old Jan 19, 2003 | 07:01 PM
DSTJ99's Avatar
DSTJ99
Default Re: Brake Specialists, please chime in!!!! (Gramps)
$400 a rotor with the hat. Thats seems a little outrageous to me :eek:
Old Jan 19, 2003 | 08:14 PM
vetterdstr's Avatar
vetterdstr
I bet under normal use "I mean normal street driving" those rotors would last the life of the car. :yesnod: They look good and would not warp too!!
vetterdstr :cheers:
Old Jan 20, 2003 | 07:14 AM
Gramps's Avatar
Gramps
Default Re: Brake Specialists, please chime in!!!! (DSTJ99)
I will grant you that it is not a cheap conversion, but it is a more simple conversion than a " Big Brake System and much less than the $2.5-6.5K that the full systems command. If / when I do this I will be the first to tell anyone if it was $ well spent.
Old Jan 20, 2003 | 09:29 PM
Untouchable00
So when I change my breaks, I just change rotors and pads. What about shoes, etc...???
Old Jan 20, 2003 | 09:49 PM
Gramps's Avatar
Gramps
Shoes? I suggest some Gucci loafers in a nice soft leather.
"etc...???" I aint goin there!
[Modified by Gramps, 8:49 PM 1/20/2003]
Old Jan 21, 2003 | 12:43 AM
corvette dave's Avatar
corvette dave
L G Motorsports (forum vendor) has a nice drilled and slotted zinc washed rotor for $150 each.
Keep your stock pads.
Dave
Old Jan 21, 2003 | 03:45 PM
jw38's Avatar
jw38
St. Jude Donor '14,'18,'21
Here's what the Eradispeed +1 rotors look like with painted calipers:
Front:
Rear:
:cheers: :cheers: :hurray: :hurray:
Old Jan 21, 2003 | 07:13 PM
CorvetteThrashers's Avatar
CorvetteThrashers
I've thought about this one up, down, left, right and sideways, and it always seems to be the calipers that run the cost up. I'm tempted to try some brembos (rotors only) and get some hats made from somewhere like:
http://www.hoerr-racing.com/
but that will be down the line a little. I would be cuious to know if anyone has thrown some 14 inchers on their car and moved the stock calipers out a bit. I've got 18" wheels on so I think they'll fit. For stock wheels you'd probably need to stick to stock size rotors.
My $0.02.
Old Jan 22, 2003 | 02:12 PM
shafman1's Avatar
shafman1
You don't have shoes on a 4 wheel disk system. Shoes are on drum brake systems which are usually just the rear.
All you will have are pads, calipers, and the rotors. Of course there are ABS sensors, and I'm not sure about the Emergency Brake set up.
Old Jan 22, 2003 | 05:41 PM
Untouchable00
Default Re: Brake Specialists, please chime in!!!! (shafman1)
Yeah, I know, shoes, pads, they are the same thing, OK, I was just in a rush. We Italians are always thinking of GQ things. That is how many guys here refer to the pads as shoes, if that is what the joke is about.
Old Jan 22, 2003 | 06:38 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Now, now, I'm new at this game myself. There are a set of brake shoes for the emergency brake. If you are going to replace the rotors, calipers, and brake pads, you will see the brake shoes when you take the rotors off. Make sure you adjust the emergency brake when replacing the rotors. Turn the adjuster out about 5 or 6 clicks at a time until you feel a slight drag on the rotor. Then do the other side. Most emergency brakes from the factory are out of adjustment. In other words, they don't hold very well.
:steering:
Old Jan 22, 2003 | 10:04 PM
Gramps's Avatar
Gramps
Sorry Untouchable00, just tweaking you a little. Had I known you were Italian, I'd have been much more respectful!
To Brake Specialists, please chime in!!!!
