Blend door calibration?
Old Jul 3, 2023 | 10:43 AM
yellow2007's Avatar
yellow2007
Default Blend door calibration?
Just watched a video on calibrating the head system blend doors on a gmail truck with dual climate control.....anybody heard of this for the c5?
Old Jul 3, 2023 | 11:19 AM
Ph300zx's Avatar
Ph300zx
I know there's a fuse you can pull and re-insert in the passenger footwall to calibrate them, can't remember which one.
Old Jul 3, 2023 | 11:30 AM
ThomasR's Avatar
ThomasR
Same. I'm sure if you search you'll find it here.
Old Jul 3, 2023 | 11:43 AM
yellow2007's Avatar
yellow2007
Pardon the spelling. I posted using my tablet....I hate touch screen keyboards.....
Old Jul 3, 2023 | 12:02 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Disconnecting the battery and allowing the system to "de charge" will cause your doors to recalibrate when you reconnect and power up.
Old Jul 3, 2023 | 12:24 PM
yellow2007's Avatar
yellow2007
Well since I disconnected the battery 2 weeks ago to try and install the LCM5 I guess I'm calibrated.......
Old Jul 3, 2023 | 12:28 PM
Smoken1's Avatar
Smoken1
Copied from another post:
Turn off the ignition.
Remove the Fuse of the HVAC control module located in the floor of the pass. side fuse box (fuse #27 only). There is another HVAC fuse (don't recall the #), it does not need removing.
Important: The module memory will not clear if the fuse is re-installed in less than 60 seconds (59 won’t reset it & you don't have to wait 5 minutes either). Wait 60 seconds minimum.
Re-install #27 fuse.
Start car, turn on AC
Old Jul 3, 2023 | 06:49 PM
carl418's Avatar
carl418
How to tell if this calibration is off? I've never heard of this before.
Old Jul 4, 2023 | 12:50 AM
Moved to C5 Tech.
Old Jul 4, 2023 | 03:12 AM
billschroeder5842
If you run a diagnostic on your DIC you will get a fault code in your HVAC module if the angle of the doors is not fully sweeping both open and closed. A recalibration will often solve this problem.
Old Jul 7, 2023 | 11:38 AM
JGarri74's Avatar
JGarri74
This happened to me after replacing a battery. Hot on drivers side and ice cold on the passenger side. Clearing the HVAC codes on the dash recalibrated the doors without the need to pull any fuses. Anything that keeps me out of that passenger side floorboard is a plus!
Old Jul 8, 2023 | 06:28 PM
grinder11's Avatar
grinder11
Amen to that, brother! I hope the brilliant GM engineer that placed that fuse panel down there needs to do this weekly, if not daily!!
Old Sep 17, 2023 | 04:26 PM
bc6152's Avatar
bc6152
Just tried pulling #27 fuse for a minute. Man, what a PITA getting to the fuse block down there... Anyway, I get no air movement but can hear the fan blowing. Tried turning the fan speed all the way up but get nothing from the vents... A/C is operating.
Old Sep 17, 2023 | 04:43 PM
yellow2007's Avatar
yellow2007
Does it blow out the defroster or floor vents at all? I'm headed to the dealer tomorrow to see if they can figure it out. My ac works but it blows out of all the vents regardless the mode selected.
Old Sep 17, 2023 | 05:01 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You have a vacuum leak in your HVAC system if air is coming out all the vents…not a calibration issue with your actuators.
Old Sep 17, 2023 | 06:31 PM
bc6152's Avatar
bc6152
Blows out the defroster opening and floor vents. Nothing from the middle top vent. Tried recirc mode and mixed mode. No air at all with fan at top speed. A/C on...
Old Oct 9, 2023 | 04:11 PM
yellow2007's Avatar
yellow2007
An update on my issue. Turns out I was right.......vacuum leak on the line going to the console. Getting that and my C1225 code error looked into
To Blend door calibration?
Old Oct 12, 2023 | 11:33 AM
Supercharged111's Avatar
Supercharged111
Are you guys all 70 years old and fat as **** or what? It's not that hard getting to that fuse panel. I am glad to hear that the recal procedure seems a lot less finicky on the C5 than it is on the trucks. The wife's Envoy is a nightmare any time you disconnect the battery, I end up hooking power to the thing elsewhere any time the battery comes out because it always overstrokes an actuator on that recal procedure which requires more setup than I've seen in this thread.
Old Oct 14, 2023 | 03:08 PM
grinder11's Avatar
grinder11
I'm almost almost 70, and not fat as ****. But I do have back problems, and have 5 vertebrae fused. Healthy, old, fat as ****, or whatever, it is still a **** location for a fuse box. Period. Hopefully, you'll make it to 70, and be healthier than I am at this age.
Old Oct 14, 2023 | 03:19 PM
yellow2007's Avatar
yellow2007
Nothing like adding helpful information to a thread.
