Could cold weather affect column lock and pull key message?
Old Jan 19, 2003 | 11:41 AM
lostsoulny's Avatar
lostsoulny
Default Could cold weather affect column lock and pull key message?
http://forums.corvetteforum.com/zerothread?id=475096
see that post for full details but basically I have been getting the pull key message every start lately in this very cold weather and then it says service column lock, and will cut ignition if I move car, column never locks though as it cant since hte dealer removed the pin. :confused: any ideas as haveing to start the car 3 times to get going is getting old real fast :mad
Old Jan 19, 2003 | 11:57 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Could cold weather affect column lock and pull key message? (lostsoulny)
http://forums.corvetteforum.com/zerothread?id=474863
Old Jan 19, 2003 | 12:54 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In V Veteran
Default Re: Could cold weather affect column lock and pull key message? (racer44)
Thats weird because I have had it happen when it was extremely hot. :confused: :confused:
Old Jan 20, 2003 | 11:49 AM
saber's Avatar
saber
Before I installed the bypass, the lock up only occured in very hot weather.
To Could cold weather affect column lock and pull key message?
