How do you replace the turn signal bulb witout taking the whole front of the dar apart.?? :confused: I thought I saw A way one time on this Forum and tried to search it out but came up empty. If anyone knows any tricks please let me know. I got A 1998 coupe. :withstupid: :withstupid: :withstupid:
Re: Right Front Tun Signal Bulb Out??? HELP (ronnie948)
There are 2 ways I have found. One is to reach in the frt brake air intake hole and push the intake duct down and out of the way, then reach your hand in upside down thought the hole (a small hand helps) push the release tab and twist the socket out and pull it out through the intake hole and change the bulb and reassemble.
Another way is to raise the front of the car remove two 7mm bolts facing the front of the car on the lower portion of the wheel well, Then there are four or five 7 mm bolts vertically underneath just behind the lower air deflector extension. This removes a small panel underneath the front bumper allowing access to the parklamp area.
Hope that helps.....
Re: Right Front Tun Signal Bulb Out??? HELP (XportC5)
It is now replaced. My friend came over for A visit and his kid's Jimmy 8 and Jason 12 changed the bulb without having to remove anything at all. Both of these kids are better mechinics then most dealers have. The skinny arms were A big help along with they knew how everything comes apart. They both work at A junk yard in the summer taking cars apart. Jason has been doing it for about 4 years. They both love cars and trucks and will someday be great Mechinics. :cheers: :cool: :flag
Last year they fixed the door on my Samuri Replaced the inner parts of the handle and latch and adjusted everything up like new.
I can't get them to wash the car even if I pay them.
:lolg:
