2003 Fuel Filter
Old Jul 11, 2023 | 08:52 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Default 2003 Fuel Filter
From my research, it appears that there may be two different types of fuel filters on the 2003 Vettes, how do I know which one mine has? The manufacturer's date is 3/2003.
On RockAuto, I can get the WIX 33737 or ACDelco GF822, can anyone please confirm that I can use these on my 03? Also, should I get new clips as well, if so, which ones?
Thanks!
Old Jul 11, 2023 | 09:35 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Your best bet is to call your friendly GM dealer and give him your VIN…he’ll check and give you the CORRECT part number…no guessing.
Old Jul 11, 2023 | 09:36 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
2003 gas tank changed with VIN 35111542 beginning on date November 25, 2002. Also the glovebox will have ffs listed. Seems like you have the ffs system, the filter is in the tank, so you probably won't be changing it.
Old Jul 12, 2023 | 03:27 PM
smitty2919's Avatar
smitty2919
AFAK, FFS or not, you still have a filter/regulator combined and mounted in the tunnel on the DS next to the trans.
Very early style fuel systems had a separate filter and regulator.
Old Jul 12, 2023 | 05:23 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Spoke with a GM Parts rep who provided me the same ACDelco part number as the one in my OP, one is on order.
To 2003 Fuel Filter
