Step inside to win a Predator handheld programmer!!!
Old Jan 20, 2003 | 01:29 AM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Default Step inside to win a Predator handheld programmer!!!
It's time to give something away! :yesnod:
One lucky forum member will be receiving a free Predator handheld programmer. The only thing you have to do is stop into this thread and say hi. We will pick a random winner on Friday, January 31st and post who it is by 5PM EST. If you are thinking about purchasing one of these this week don't let this offer stop you. If your name is drawn we will credit your account for the full amount that you paid plus shipping. Our regular price for this item is $439.99 and our current 10% off special can be applied to all ignition/tuning products. Please only one post per member. This offer isn't open to moderators and other vendors (sorry guys :)).
I've included product information below. If you have any tech questions please post them in a different thread because this one will probably get long and I don't want them to get lost in all of the posts.
The Predator is the most advanced tuning programmer available today. It has taken the hand-held programmer to a new level. You will notice quicker acceleration and better throttle response. If you have an automatic transmission, the Predator will also give you a firmer, more responsive shift pattern (gas vehicles only at this time). The Predator will raise your rev limiter as well as it allows you to raise your top end speed limiter if you have installed high speed rated tires.
Lifetime Warranty!
Screen Size that is 300% larger than the competition
Quicker programming (takes approx. 2 min.)
Custom Files can be downloaded from internet which allows for future updates
and customized programming
OBD-II diagnostic software (includes live data monitoring of MPH, RPM, IAT, ECT, LTFT, STFT, O2 voltage, timing, knock retard detection, as well as many other sensors
Eliminates CAGS (Skip Shifting) on the 6-speed manual transmissions
Revised Torque Management Settings for optimum performance
User adjustability. the user can set their own parameters - Choose from DiabloSport's performance program, have a custom performance program made for you by a Diablo Tuner, or create your own:
a. Richen or lean fuel mixture
b. Advance or retard ignition timing
c. Raise and lower shift points in 10 RPM increments
d. Raise and lower rev limiter in 10 RPM increments
e. Reduce shift duration (time delay during gear change) (+/- 25% and anywhere in between)
f. Increase or decrease shift firmness (+/- 25% and anywhere in between)
g. Correct speedometer for gear changes and/or tire sizes
h. Turn on cooling fans at lower temps in incremental steps of 1 degrees (for vehicles w/ factory equipped electric fans)
i. Adjust top-speed limiters (eliminates on the Y and F-bodies)
A unique feature of the Predator is that is allows you, the user, to “fine tune” DiabloSports program. Since vehicles are located at different elevations or different weather climates, the way the vehicle responds to the DiabloSport program may vary (not all vehicles are exactly alike). Some vehicles will see better gains than others and some may see better (or worse) gains than advertised. This is due to the fact that not all vehicles respond exactly the same. Now, here’s the good news…If you're not totally satisfied with the way DiabloSport program performs, the Predator allows you to make your own adjustments to the program. For example: If you feel that the shift points are too firm, you can go into the program and lower the transmission line pressure (gas vehicles). If you feel that you can benefit from a higher shift point rpm, you can go into the program and raise shift points. If you feel that you will benefit from a few more degrees of ignition timing, you can go into the program and add some timing (gas vehicles). The Predator allows you to "fine tune" the DiabloSport program to meet your specific requirements.
The Predator has diagnostic abilities near identical to GM’s Tech2 software. The predator will allow you to read diagnostic trouble codes (DTC), erase DTC’s and perform live data monitoring. You can monitor your engine sensors while driving your vehicle and much more.
This product will save the original GM program so if at any time you want to go back to the original factory specifications, it will allow you to do so.
Good luck!
Tom
[Modified by tbyrne, 1:41 AM 1/20/2003]
Old Jan 20, 2003 | 01:36 AM
USMUSCL's Avatar
USMUSCL
St. Jude Donor '05
Default Re: Step inside to win a Predator handheld programmer!!! (tbyrne)
Hey,
Awesome offer-I'm in :cheers:
Old Jan 20, 2003 | 01:58 AM
Domin8r's Avatar
Domin8r
I'm in, thanks :cheers:
Old Jan 20, 2003 | 02:24 AM
corvette184's Avatar
corvette184
Default Re: Step inside to win a Predator handheld programmer!!! (Domin8r)
i would love to give it a try.....count me in :yesnod: :yesnod: :yesnod: :yesnod:
Old Jan 20, 2003 | 03:47 AM
Tim 02 WS6's Avatar
Tim 02 WS6
I vant one!! I vant one!! :cheers:
Old Jan 20, 2003 | 04:03 AM
mathia's Avatar
mathia
Hi!
Sign me up. The more give aways the better :cool:
Old Jan 20, 2003 | 04:50 AM
yellowvette837's Avatar
yellowvette837
St. Jude 15 Year Donor
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
:hurray: That is so nice of you :hurray:
Put me in the drawing
[Modified by yellowvette837, 3:51 AM 1/20/2003]
Old Jan 20, 2003 | 05:01 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Put me in please :)
Old Jan 20, 2003 | 05:17 AM
Corvette Poor's Avatar
Corvette Poor
H I ! Count me in.......Thanks for the generosity !
Old Jan 20, 2003 | 05:19 AM
blktie8's Avatar
blktie8
Got to have it! hope I'm in?
John
Crushinator's Avatar
Crushinator
Default Re: Step inside to win a Predator handheld programmer!!! (Corvette Poor)
Hi!
Old Jan 20, 2003 | 06:01 AM
Corvette4ever's Avatar
Corvette4ever
HI
I'll be purchasing some stuff from you soon.
Old Jan 20, 2003 | 06:21 AM
dlw98c5's Avatar
dlw98c5
Hello and put me in for a chance to win a Predator :flag :hurray:
Old Jan 20, 2003 | 06:33 AM
add's Avatar
add
Sweet, count me in!
TD
:cheers:
Old Jan 20, 2003 | 06:37 AM
quimbo's Avatar
quimbo
Hi!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
QUIMBO :seeya :seeya SEEYAAAH :steering: :steering:
Old Jan 20, 2003 | 06:55 AM
blk05coupe's Avatar
blk05coupe
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
sign me up.... :seeya
Old Jan 20, 2003 | 07:10 AM
geekracer's Avatar
geekracer
Hi!
To Step inside to win a Predator handheld programmer!!!
Old Jan 20, 2003 | 07:12 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
:seeya Tom
Old Jan 20, 2003 | 07:20 AM
thefly's Avatar
thefly
woohoo, i want one.
Old Jan 20, 2003 | 07:27 AM
Gray Ghost's Avatar
Gray Ghost
Please put me on the list
The Gray Ghost :steering:
