C5 converiable window repair
Old Aug 1, 2023 | 04:50 PM
rrwirsi's Avatar
rrwirsi
Default C5 converiable window repair
If you are having a soft top convertible rear glass detachment issue as I had for the past 4 years. I decided to try different glue. I been using RHINO GLUE but it only held for about 12-15 months. So in my quest to find a more permanent option, I found through CF and the ‘Net” recommendations on another option; 3M WINDO-WELD (#08609) pus the3M Single Step Primer(08682) that was recommended.
Although I could not find any videos on the ‘net’ for the C5 convertible rear window re-glue using the 3M, I did find a video for doing a Mini Cooper rear window repair using the 3M product.
Amazon.com: Brixwell SNC6 Suction Cup Clamp Set 6 Pack Glass Clamp for Convertible Top Body and Windshield Repair Suck-N-Clamp : Automotive Amazon.com: Brixwell SNC6 Suction Cup Clamp Set 6 Pack Glass Clamp for Convertible Top Body and Windshield Repair Suck-N-Clamp : Automotive
Using the video, I followed the instructions for cleaning the glass and gluing procedure but added these steps for the C5:
1. Remove the two electric de-frost wires on each side of the window by gently pulling the connectors out. No need to take the glass out. Just clean the glass and remove old glue stuff from the fabric and glass.
2. Open the top and put a 12 inch brace between to windshield top and the convertible top edge so it loosens the fabric.
3. Put small pillows pushing against the glass from the inside.
4. If you use Suction Cup Clamps, a tip; use dawn soap mixed with water on the cup underside. It will keep the suction cup firmly attached to the glass. It really holds.
5. My chemical engineer neighbor suggested not doing the glue repair in the hot sun. I did the repair in the shaded garage.
6. Do the top and sides first then let dry for about 3 hours. Then do the bottom.
7. I did the cleanup 12 hours later.
Hopefully, this repair is permanent. I have no desire to replace a perfect good top just to fix the rear detachment window issue.
Old Aug 1, 2023 | 10:16 PM
Thanks for posting this for other convertible owners to reference.
Moving this to C5 Tech.
Old Aug 2, 2023 | 09:00 AM
grinder11's Avatar
grinder11
You won't be sorry using the 3M WW. I fixed mine 9 years ago this month. Looks factory, doesn't leak water or air. Good as new. I swear, if this stuff was allowed to glue your hand to a surface, you would never get your hand off that surface again! It is GREAT stuff!!!
To C5 converiable window repair
