Unfortunately not, I just refuel on the lowest speed and then make sure the amount makes sense when I finish. Usually it clicks off at half way. Issue is worse on the new sealed pump nozzles.
To the right (rotating it counter-clockwise 90 degrees). I'm in California, so yes, there is the vapor recovery. It always clicks off if I just stick the nozzle in normal, unless it's a really slow pump.
