Which Thermostat?
Old Aug 11, 2023 | 04:30 PM
vito02's Avatar
vito02
Default Which Thermostat?
I will be doing a coolant flush on my newly-purchased 03Z. I understand that there was a production change where the later LS6s use a thermostat integral with the pump-inlet housing [o-ring seal] while the earlier cars use a separable thermostat and a different gasket.
The factory service info suggests that I have the integral variety and looking up the part via the VIN shows GM part 12571261 for the t'stat/housing assembly and 12561155 for the housing 0-ring.
My car is 10-02 production. As far as I know the coolant pump is original.
Are these the correct parts?
Old Aug 14, 2023 | 11:09 AM
ThomasR's Avatar
ThomasR
Buy both and return the one you don't need.
Old Aug 15, 2023 | 09:25 AM
grinder11's Avatar
grinder11
You have it backwards! The early style is all one unit, i.e., the t-stat is integral with the inlet housing. T-stats were $50+ due to buying more than just the stat. Later ones were a separate stat, like they'd used in most all cars for at least 50 years. They are much cheaper. I believe the later stat is GM #12600172, which is a 195° stat (I think!), but please double check my info. You may want to go with a 180° stat. If so, the above part# wont be a 180° stat.....
Old Aug 15, 2023 | 03:27 PM
vito02's Avatar
vito02
Thank you, Grinder.
Do you think the later, separable thermostat, version uses the o-ring seal for the housing? I am removing the t'stat to do a good flush.
Does a 180F thermostat set "Cooling System Performance" trouble codes [Typically a P2181]?
Old Aug 18, 2023 | 12:15 PM
6speedsteve's Avatar
6speedsteve
Thank you, Grinder.
I installed a 180 in mine & have had no codes.
Old Aug 18, 2023 | 07:59 PM
grinder11's Avatar
grinder11
Thank you, Grinder.
As for the O-ring, yes, I haven't seen an LS1/LS6 housing that didn't use an O-ring. A 180 stat will cause no codes......
Old Aug 19, 2023 | 12:36 AM
jim993's Avatar
jim993
The two style thermostats are NOT interchangeable without changing the water pump also. Different hole diameter in the water pump for each style.
Old Aug 19, 2023 | 03:30 PM
grinder11's Avatar
grinder11
Damn, Jim!!! Glad you posted this. Learn something new every day.......
To Which Thermostat?
