Bad starter?
Old Aug 15, 2023 | 03:48 PM
Zerosraven's Avatar
Zerosraven
Cruising
Default Bad starter?
Hi guys, looking for some help with my c5. I was experiencing bad alternator whine so I got that replaced as well as a new battery. All was well for a few days as car started/ran perfect. 2 days ago (while driving) I received a bunch of pings out of nowhere - “service ABS, low wiper fluid, service traction control, TPMS” and the like. Car was still driving fine. I read that it could be a result of a new battery, so I was just gonna get my friend with a obd to clear codes and see if any of them came back. (Reset button doesn’t work)
Yesterday I go to start and car clicks but that’s about it. I get “low voltage” so now I’m kinda lost. Today, no electrical power at all. It’s a new battery, new alternator, and car was running fine. After hours of YouTube videos I believe it is a - bad starter/bad ground somewhere, and I would just like to ask for some other ideas before I take the car apart.
File Type: mov
Old Aug 15, 2023 | 04:47 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Even though it's a new battery make sure you don't have a parasitic drain...your battery may be draining overnight...if you put voltmeter in the AMPS function remove the negative battery cable and put the DVOM leads in series between the battery negative post and the battery cable...see if you see a large current draw...close the doors and wait about 20 minutes until the cars modules go to sleep before testing...max draw is about 25-30 milliamps...fully charged battery is 12.66 volts
Old Aug 15, 2023 | 07:43 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Double-check that your new alternator is suitable.
https://www.corvetteforum.com/forums...nd-issues.html
Old Aug 15, 2023 | 08:30 PM
Zerosraven's Avatar
Zerosraven
Cruising
thank you for the advice. I will go out and buy a voltmeter soon. I suspected the battery however the car wouldn’t even jumpstart when I tried today. There’s just no power at all. Could this still be a result of parasitic drain?
Old Aug 15, 2023 | 08:31 PM
Zerosraven's Avatar
Zerosraven
Cruising
Thanks! I’ll read up on it
Old Aug 15, 2023 | 08:42 PM
C5 Diag's Avatar
C5 Diag
If the battery is completely “spanked” the car may not start…I got a mobile call from a C6 owner in town a few months ago that couldn’t get his car started…he did not have it on the tender for about a month…battery was maybe 2 volts…I couldn’t even jump it with my jump pack …I removed the battery and put it on my big battery charger for 30 minutes…I finally got the battery to take a charge and was able to get the car started….you may have a drain and the more the battery becomes sulfated it shortens it life SIGNIFICANTLY !!…good idea to have a good DVOM and 12 volt test light.
Old Aug 20, 2023 | 04:12 AM
Moved to C5 Tech.
Old Aug 20, 2023 | 10:48 AM
dainon's Avatar
dainon
Totally agree.. ^^^
My '99 won't even crank with less than 11.6 volts. A fully charged battery should give you 12.5. You may have a ground problem if you are getting random codes that don't seem related. Once you get it started again, check your voltage on the battery while it's running. Turn your a/c on, headlights, etc. Get a real good load on that alternator. You should still be seeing 13 volts or more with all of that going on. If not, then you know it's either a bum alternator or the grounds.
To Bad starter?
