Steering wheel not moving with memory function
Old Aug 16, 2023 | 08:39 AM
forpetessake38's Avatar
forpetessake38
Default Steering wheel not moving with memory function
When pressing the memory buttons everything else works like normal except the wheel. It will go back in when you take the key out, easy exit mode, or whatever it's called. And the wheel moves perfectly fine when adjusted manually, it just won't go into the memory position when the car starts or when you press either memory button. Any ideas?
Old Aug 16, 2023 | 10:49 PM
xcarter's Avatar
xcarter
Is this what happens if the steering column position sensor goes out? Any codes in the DIC?
