P0332 Help
Old Aug 16, 2023 | 02:03 PM
ltnate's Avatar
ltnate
Default P0332 Help
98 Stock MN6...changed both sensors and harness yet I still get this code. Any help would be greatly appreciated. BTW, checked voltage and sensor and harness seem to be ok.
Old Aug 16, 2023 | 03:36 PM
Dads2kconvertible's Avatar
Dads2kconvertible
These are from a 2000 service manual, yours may be different.
Old Aug 16, 2023 | 03:44 PM
ltnate's Avatar
ltnate
Thank you
Old Aug 16, 2023 | 03:45 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Best to use OEM sensors if you can find one…the sensor must be torqued properly…video below on how to correctly diagnose these.
Old Aug 17, 2023 | 02:05 PM
ltnate's Avatar
ltnate
I used OEM...is it strange that the same knock sensor is throwing a code?
Old Aug 17, 2023 | 02:17 PM
C5 Diag's Avatar
C5 Diag
The sensor generates a small voltage that goes to the PCM…I’d check the wiring from the harness to the PCM…you may have high resistance in that wire.
To P0332 Help
