Reduce Power, Service Traction Control?
Old Aug 20, 2023 | 10:32 AM
billdance's Avatar
billdance
Default Reduce Power, Service Traction Control?
Pulled up to the light yesterday and a reduce power, service traction control popped up. Car would idle, but wouldn't drive. I restarted it, same error, tried again two more times and finally was able to drive home. 1998, Conv 68K miles.
Current codes I had were:
A1 - RDCM B2265H
40 - BCM B2723H
28 - TCS C1278H
10 - PCM P1518H
Did some forum searches and it seems all over the place. From right or left door error, mirror, steering wheel, battery/Voltage, etc. I did recently have the harmonic balancer replaced and I hope they didnt mess up the steering wheel alignment sensor. I had that code pop up right after the work, but not seen any issues.
Any thoughts? I drove it the rest of the day and no issues. Put it on the charger as I normally do over the winter. Battery is not about 7-8 yrs old, so may be battery?
Barry.
Old Aug 21, 2023 | 11:49 AM
mmartinez's Avatar
mmartinez
Many times the cause of the problem is never found, I have also had this occur to my 97, and I disconnected the battery for 10 minutes or so, you might want to put a DVM across the battery terminals and verify that it is at 12.5. Our cars are very sensitive to low voltage conditions.
Old Aug 21, 2023 | 03:10 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A1 - RDCM B2265H
40 - BCM B2723H
28 - TCS C1278H
10 - PCM P1518H
Barry.
You say your battery is 7-8 years old ????….time for a new one !!
Old Aug 21, 2023 | 06:37 PM
billdance's Avatar
billdance
Thanks all. I drove it yesterday and not one issue. I'll replace the battery this weekend. I see Costco has Interstate too.
Old Aug 24, 2023 | 12:36 AM
jim993's Avatar
jim993
AGM batteries are much less likely to leak and destroy wiring harness below the battery or the PCM.
To Reduce Power, Service Traction Control?
