Expansion tank Cap
Old Aug 20, 2023 | 12:37 PM
mran1's Avatar
mran1
Default Expansion tank Cap
I'm in the process of replacing my thermostat in a 04 Z06. Was curious about the expansion tank cap. Mine is a 15lbs cap but I see the replacements are 18psi.
Why the change? I know this increases the boiling point of the dexcool but I never had an issue with overheating. With a 20 year old car, I figured it may be a good idea to put a new one on but am reluctant to increase the pressure.
​​​​​​Am I overthinking this or should I try to find a 15lbs cap?
Thoughts?
Old Aug 20, 2023 | 12:49 PM
SilverC54me's Avatar
SilverC54me
GM changed the spec during the C5 production run. Your 2004 should have had the 18lb cap. You are good to go with the 18lb cap.
Also inspect the expansion tank, those are known to leak at the seams.
Gary
Old Aug 20, 2023 | 07:34 PM
redzg's Avatar
redzg
I have a cracked radiator tank — switching to 18 PSI made it significantly easier to find.
Old Aug 20, 2023 | 10:14 PM
mran1's Avatar
mran1
I Simply applied 18lbs of pressure to the tank to check for leaks with a pressure pump.
While I understand GM changed the cap, I don't see a reason to as it never previously overheated and adding additional pressure may cause some other unwanted issues.
I think I will keep it at 15lbs for now.
Thank you both for your input.
Mark
To Expansion tank Cap
