I've noticed that a lot of people recommend Hawk brand brake pads for the C5. I'm going to have to replace the rear pads on my '02 Coupe soon. Which Hawk pads are recommended for a street-only C5? I don't hammer it but I do drive aggressively at times and stop the same way sometimes. Looking around, it appears there are several types of Hawk pads.
Also, if I put Hawk brand on the back, should I replace the front at the same time with Hawk? In other words, are the Hawk pads that much better than stock that putting a set on the back could cause a problem if I don't also replace the front with Hawk?
My rotors are in good shape front and rear so I won't be replacing them at this time.
Thanks in advance.
For a high quality low dust performance street brake pad take a look at the Carbotech 1521 brake pad 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and contain NRS Technology Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use. __________________ Adam Adelstein Amp’D Autosport.com Internet's largest retailer of Carbotech Performance Brake Pads. PH:216-780-8825. Email: sales@ampdautosport.com Web Site & Direct ordering http://ampdautosport.com/ All major CC and Pay Pal accepted. Check out Promo code:z28
I have Hawk HPS pads on my 2004 C5 and like them. No noise, no pulsing, great cold bite. Dust about like oem. I'd replace all your pads at the same time.
VS
VS
When you put them on, did you also replace rotors? I'm wondering how they would do with old (but good) rotors.
I put them on using my original rotors. I talked to Hawk and they said the pad material is totally compatible with the pad material in the oem pads. I did not sand or resurface the rotors in any manner. I bedded them according to their instructions and am totally pleased with them. I have not had them on the track (although I did some HPD events on the oem pads) but I feel confident they will perform at least as well. I have tried them out on some of the curvy roads where I live and have not experienced any fade. (I run Castrol SRF or their new stuff for brake fluid.)
