I had a Centerforce dual-friction clutch installed about 4 months ago. It is making a tapping noise when I have the clutch pedal all the way out. It seems to get louder in cold weather and when the A/C is turned on. I can make it go away be pressing the clutch in approximately one inch. Sometimes I can push the clutch in a few times and let it out again and the noise goes away. The folks I had install the clutch said the clutch seemed fine but it is embarrassing sitting at a light with a loud tapping noise going on like my engine is about to blow. By the way it never did this with the stock clutch. Anyone have any ideas?
I had a similar knocking problem at idle.
I could make the knocking stop by putting a little fore or aft pressure on the shifter while in neutral, or by depressing the clutch an inch or two.
My problem turned out to be a bad clutch release bearing.
Good luck in solving yours.
