Rare column lock isssue
Old Sep 12, 2023 | 07:00 PM
zman1144's Avatar
zman1144
1st Gear
Default Rare column lock isssue
My 98 is an early build Went thru the GM recall that’s when things went south. Had the pull key issue and was on speed dial with compliance parts Richard. I did the LMC5 module but it did not fox the issue. Can’t do the brown wire fox because my 98 build is to early. I got a new BCM installed and instead of pull key I now just have the column lock message which I erase with the reset I’m just wondering if anyone else ever had this same type of issue? Just the column lock message. Car drives perfect. Brand new battery.
Old Sep 12, 2023 | 07:34 PM
Moved to C5 Tech for assistance.
Old Sep 12, 2023 | 08:08 PM
Supercharged111's Avatar
Supercharged111
I've had it before. I don't remember if that was before or after I wiped that all out in my tune though. Haven't seen it in a while now.
Old Sep 20, 2023 | 09:02 PM
kkupec02's Avatar
kkupec02
welcome
To Rare column lock isssue
