Idler Pulley
Old Sep 16, 2023 | 03:49 AM
ariZona06's Avatar
ariZona06
Default Idler Pulley
'03 Z06 w/LS3 crate. Just got my fancy Katech Belt Tensioner, installing new Gates Serpentine belt and figured while I'm at it I might as well change the Idler Pulley. Any recommendations for a good quality unit? Car is mostly track duty so I don't want to cheap out. Been thinking AC Delco but I'm open to other brands. Any brand to avoid? TIA.
Old Sep 18, 2023 | 11:34 AM
grinder11's Avatar
grinder11
I've had my OEM tensioners in place since new, with only one issue. I knew the A/C idler was wearing out, as it was on a slight angle. Well, I had it replaced when I had a new compressor/drier/condenser installed. Now I have a squeaking up front somewhere. IDK what brand idler the shop used, but guessing it's not OEM. So, also guessing that the new tensioner is the culprit. I recommend OEM, because mine went 130,000+miles in 22 years. Hope this helps......
Old Sep 21, 2023 | 05:17 AM
ariZona06's Avatar
ariZona06
Found one local at the last remaining REAL autoparts store in my region, Rieth Autoparts in Mesa. Gates 36225, made in Canada. NOT China. About $40 with tax. Installed it, new Gates belt and Katech tensioner. On to the next project.
Old Sep 21, 2023 | 10:48 AM
tabbruzz's Avatar
tabbruzz
Open the seals gently, fill it with grease and let her rip........Or GM is fine...Pretty cheap part
Old Nov 24, 2023 | 06:44 PM
liamricci's Avatar
liamricci
Banned Scam/Spammer
Did you find one actually?
Old Nov 27, 2023 | 01:51 AM
ariZona06's Avatar
ariZona06
Yes.
Old Dec 29, 2023 | 09:44 AM
BmoreRnsDeep's Avatar
BmoreRnsDeep
When mine went and was screeching I had a hell of a time finding the right OEM unit. I opened up the seal on the old one, filled it with grease, pounded it closed and it has worked ever since.
To Idler Pulley
