Another column lock question
Old Jan 21, 2003 | 10:26 PM
scool93535's Avatar
scool93535
Default Another column lock question
I purchased my 97 used. I don't know if the previous owner had the CLB installed. :(
I've read on a board, maybe this one, that a column lock may be proceeded by the "Security" indicator on the dash coming on just before the column locks up. :skep:
Two questions - 1. Is there an easy way to check to see if the CLB has been installed? :confused:
2. My security indicator has been comming on more offten then it use to, should I be worried? :eek: This started after a case of severe wheel hop at the WCCC. :mad
Your thoughts please.
:cheers:
Old Jan 21, 2003 | 10:43 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Another column lock question (scool93535)
If the column lock was done under recall just contact your local Chevy dealer with your VIN and they should be able to tell you if had been done.
If it hasn't your should have it done. There have been over 300 reported incidents of the column lock happening while driving.
regarding the security light...I would check the codes and see what's been thrown.
To check the codes: cycle the key to on, wait for the message to clear, then hold the options button down and hit the fuel button 4 times. The DIC will go into code diagnostics mode and start reporting codes. don't worry about them flashing by you can scroll up/down with the other buttons when it's done. And yes, holding in reset will erase the code you are on or all of them in the group if you are on the group list.
Old Jan 22, 2003 | 01:16 AM
wottogo's Avatar
wottogo
If you have an after market CLB the wheel will still turn after you lock it up and remove the key. :steering:
Old Jan 22, 2003 | 01:33 PM
scool93535's Avatar
scool93535
Default Re: Another column lock question (wottogo)
Oops! :mad Mine locks when I take out the key. I guess I should start worring. :banghead: :banghead: :banghead:
Old Jan 22, 2003 | 02:07 PM
Gash Hunter's Avatar
Gash Hunter
with clb ( column lock bypass) installed the steering wheel will not lock.
To Another column lock question
