More C5 ABS fun, advice appreciated
Old Sep 19, 2023 | 05:49 PM
strano@stranoparts.com's Avatar
Supporting Vendor
Default More C5 ABS fun, advice appreciated
2004 Z06. Does not show any issue with no communication with the EBCM, but getting the following codes:
C1232 LF Wheel Speed Circuit Open or Shorted
C1233 RF Wheel Speed Circuit Open or Shorted
C1234 LR Wheel Speed Circuit Open or Shorted
C1235 RR Wheel Speed Circuit Open or Shorted
Also on about Master Cylinder pressure, which I don't recall the code on.
The most simple thought is common EBCM issues, but to lose all 4? Has that happened to anyone else? I've seen where folks lose both rears, or both fronts.
This is the big hold up to getting this C5 back on track. I'm good at suspension stuff, wheels and tires, more than electronic stuff. I would certainly appreciate any thoughts, or to know if anyone else has seen this and what the solution was.
Thanks all.
