C5z pop up headlight issue, need help
Old Sep 20, 2023 | 06:44 PM
mammoth713's Avatar
mammoth713
Default C5z pop up headlight issue, need help
Driver side headlight has been intermittently popping up. I turned the **** thing slightly and then it will pop up now but now makes noise when going back down.
It will stow but then headlight motor continues to spin. Seems to me like gear teeth are worn and not tripping some sensor to tell it the headlight is down? Is this gear teeth being worn down issue or something else?
Here is clip:
https://youtube.com/shorts/l2PQwcUpi6w?si=ffMSuci-LbB-ChsT
Old Sep 20, 2023 | 06:54 PM
jdmvette's Avatar
jdmvette
Night Owl for life
You need a new gear or motor. Motors are cheap and easy to get it running like new...that's what I'd recommend replacing
Old Sep 20, 2023 | 09:32 PM
mammoth713's Avatar
mammoth713
[QUOTE=jdmvette;1607064587]You need a new gear or motor. Motors are cheap and easy to get it running like new...that's what I'd recommend replacing[/QUOTE
Replacing the motor vs the gear is a big difference…
is there a sensor that tells the motor to stop spinning once the headlight is stowed? Im confused why it keeps spinning once it’s already stowed
Old Sep 20, 2023 | 09:34 PM
_zebra's Avatar
_zebra
because the broken/missing teeth don't provide the physical resistance the headlight motor's looking for to stop running
Old Sep 20, 2023 | 10:14 PM
wca_tim's Avatar
wca_tim
Here is clip:
https://youtube.com/shorts/l2PQwcUpi...MSuci-LbB-ChsT
do the brass gear replacement...
Old Sep 21, 2023 | 12:44 AM
jdmvette's Avatar
jdmvette
Night Owl for life
replacing the motor is 3 bolts + a nut R&R vs opening the motor itself to do the gear swap then doing the exact same thing.
Old Sep 21, 2023 | 07:44 AM
mammoth713's Avatar
mammoth713
I have a 2004... What year did they switch from sealed housing to the version with screws? (If it's the sealed one then I'd rather buy the whole motor assembly)
Old Sep 21, 2023 | 07:59 AM
ncali's Avatar
ncali
Mammot, yours will be a sealed unit. changing the gear is very simple. you can look up Rodney dickman for a kit. it comes with complete instructions.
when working properly the motor turns the headlights until a resistance is sensed
Old Sep 22, 2023 | 06:38 PM
tookielee's Avatar
tookielee
I just ordered a new motor from Ebay, 15 minutes ago, for 39.00. A new gear would be close to 30.00, not worth the work
https://www.ebay.com/itm/18494580330...Bk9SR9zr5PDXYg
Old Sep 22, 2023 | 11:46 PM
ncali's Avatar
ncali
But you will be replacing it again. I got the brass gears that will not strip like the nylon gears
Old Sep 23, 2023 | 12:16 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Yeah...in another 20 years
Then you buy another dirt cheap motor and you're good for 40...that should last most people
Old Oct 10, 2023 | 03:01 AM
mammoth713's Avatar
mammoth713
Thanks everyone for the help…
I’m gunna just buy assembled motor since mine is 04 with sealed unit. I’d rather not waste time trying to seal the motor back up etc. These lasted 20 years… lol that’s good enough
Old Jun 29, 2024 | 01:30 AM
_zebra's Avatar
_zebra
oh dang... came back here to grab auction site links for the (now) $64 double motor pack so i can finally get to buying parts
but daggum if they ain't now selling brass gear kits for $37 - that does both sides. decisions, decisions...
To C5z pop up headlight issue, need help
