Long crank / weak start when warm
Old Sep 26, 2023 | 01:12 AM
ViperVS's Avatar
ViperVS
3rd Gear
Default Long crank / weak start when warm
Hi. I'm having an issue with starting the car sometimes (especially with warm engine). Might crank up to 5 seconds hesitates even then. Other times it starts up like a brand new car (usually when cold). At least it does start every time, it's just embarrassing.
General opinion seems to be that this is caused by weak fuel pump prime. And I tend to agree, since if I prime it few times (ignition on/off x 3), it does start much better.
But can someone explain me the logic behind this phenomenon? How can the fuel pump work completely fine while driving, even with full throttle, but at the same time is also weak enough to just prime the fuel rail pressure for start? And why does it start much better when cold? Does it not sometimes prime at all when it's warm?
And the fix would be to replace fuel pump?
Old Sep 26, 2023 | 07:00 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you have to prime the fuel pump prior to starting may be a faulty fuel line check valve (fuel draining back to the tank) or maybe a cam or crank sensor issue…hard to diagnose without testing.
Old Sep 26, 2023 | 07:13 AM
ViperVS's Avatar
ViperVS
3rd Gear
Thanks for the reply. I don't have to prime the pump. It will start every single time. It just sometimes cranks longer that it should. Mostly when engine is already warm. I also forgot to mention that I don't have any fault codes.
"check valve (fuel draining back to the tank)"
Shouldn't the fuel pump prime every time once I turn the ignition on (despite the engine being warmed up from last drive)? Surely it will not drain back in half a second before cranking. And why doesn't it drain back when the engine is cold?
Old Sep 26, 2023 | 07:28 AM
C5 Diag's Avatar
C5 Diag
If you cycle the key a few times before every time before starting and now it starts normally every time the fuel feed line is losing prime…a quick way to tell if a bad CRANK sensor is watch the Tach during starting…if it doesn’t move it may be a faulty sensor…unless you can get yourself a fuel pressure gauge and a labscope to test the cam and crank sensor you will only be guessing.
Old Sep 26, 2023 | 08:37 AM
ViperVS's Avatar
ViperVS
3rd Gear
Just tested, and zero movement during crank, even though it fired up great this time. So looks like I'll be replacing the sensor. Thanks for the tip!
Old Sep 26, 2023 | 11:44 AM
Fast one's Avatar
Fast one
Aren't the gages including the tachometer powered by the ignition run circuit that is off during cranking?
Old Sep 26, 2023 | 12:20 PM
C5 Diag's Avatar
C5 Diag
No, the PCM uses the crank sensor reference pulses to drive the Tach…if you hold your foot down on the gas pedal and keep it to floor the engine will only crank…you can see the RPM roughly 150 RPM or watch it if you have a scan tool.
Old Sep 26, 2023 | 01:21 PM
Fast one's Avatar
Fast one
That's interesting because my '98 also has the sometimes difficult to start problem. There is no tach movement during cranking but the sensors have been changed. The next step will be to check the wiring to the crankshaft position sensor and for a possible bad new sensor. One thing I never did was crankshaft position learn procedure.
Old Sep 26, 2023 | 01:28 PM
C5 Diag's Avatar
C5 Diag
If you used an aftermarket sensor like a Dorman for instance that can be your problem…you ALWAYS check the wiring before replacing…it’s a 3 wire Hall Effect sensor…12 volt power, a ground, and a signal to the PCM…with a labscope you will see a 0-12 volt square wave..with a voltmeter you will see around 3-4 volts if I can remember.
To Long crank / weak start when warm
