Sleepy eye conversion. Light halo's, show mode?
Old Sep 30, 2023 | 10:42 PM
Turkey Lips's Avatar
Turkey Lips
8th Gear
Default Sleepy eye conversion. Light halo's, show mode?
Anyone done the knight drive tv sleepy eye headlight conversion? Is there a way to use the halo's without have the taillights on, for "show mode"? To have on when parked at car meets? Thanks in advance. I'm not used to forum style posts, so I apologize if this has been asked before.
Old Oct 1, 2023 | 03:12 PM
rrwirsi's Avatar
rrwirsi
I do not have the headlight conversion but try pulling fuse #6 in the fuse compartment on the Passenger side.
Old Oct 2, 2023 | 05:56 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Personally, I'd want the KDTV halos and rear laser halos together but yeah, surely you can pull a fuse
Old Oct 2, 2023 | 09:59 PM
Mc556's Avatar
Mc556
I have them and they are awesome.
The halo lights tap into the brown power wire for DRL lights. You can tap for power to any place you want. The lights do not stay up when the switch is off I’m not sure by the way you’re asking the question if you realize that. If you wanted them to stay up in a sleepy eye all the time you could probably disconnect the motor. Definitely a bit Ricer, but your car
The lights themselves are amazing compared to what came stock
Old Oct 8, 2023 | 10:12 AM
saxtonfwd's Avatar
saxtonfwd
Default Knight Drive TV headlights and halos
I have the squares, had had them for a year or so. My experience the way they are wired if you want just the halos, it will be in parking light mode. First you will put your headlights on, then back it off to keep them up in halo mode. Yes, your tail lights and side markers will stay on unless you can find a different way to wire them. I have halos in the rear with led side markers as well so I don't mind it.
To Sleepy eye conversion. Light halo's, show mode?
