No crank no start help reduced engine power
Old Oct 1, 2023 | 11:14 PM
Brokec5270's Avatar
Brokec5270
Cruising
Default No crank no start help reduced engine power
Ok so I’ll start off by saying what all we have replaced it’s my buddies corvette it’s a 98 auto vert car. It has a brand new starter, battery 120rc, ignition switch, I also bypassed the vats the key is #7. We have cleaned and taken the grounds off and cleaned them from all the corrosion. It’s still doing them same thing maybe the resistor for the bypass isn’t working right? Since I bypassed the vats there would be no need for him to buy a new tumbler right?? I’m helping him as much as I can Im no professional so I’m just going off all the research I’ve done and still at this point. Any help would be greatly appreciated
I pulled the codes from the dic
40-BCM NO COMM
60-IPC U1176 H C / U1040 H
80- Radio U1076 H
99-HVAC NO COMM
AO-LDCM NO COMM
A1-RDCM NO COMM
BO-RFA U1096 H U1064 H C
28-TCS C1255H C1276 H U1016 H
10-PCM P1626 H C
Old Oct 2, 2023 | 10:08 AM
Brokec5270's Avatar
Brokec5270
Cruising
Tttt
Old Oct 2, 2023 | 10:39 AM
rrwirsi's Avatar
rrwirsi
You mentioned bypassing the vats. Was it done as noted in the video?
Old Oct 2, 2023 | 12:20 PM
Brokec5270's Avatar
Brokec5270
Cruising
c5 corvette vats bypass - YouTube
no I did it at the ignition a locksmith told me how to do it should I do it like the video?
Old Oct 2, 2023 | 12:56 PM
mmartinez's Avatar
mmartinez
It really doesn't matter where you install the resistor.
Old Oct 2, 2023 | 01:14 PM
Brokec5270's Avatar
Brokec5270
Cruising
also his steering wheel moves freely it’s on jack stands right now but it’s not locking
Old Oct 2, 2023 | 03:25 PM
rrwirsi's Avatar
rrwirsi
Nothing to loose but doing it again at the video's location with the proper OHM resistor.
Old Oct 2, 2023 | 06:14 PM
Brokec5270's Avatar
Brokec5270
Cruising
ok may try that too I’m not familiar with all those codes and looked all of them up still can’t figure out what’s wrong with it tho. P1626 is tdr delay malfunction. I pulled it out lastnight and jumped the red and purple wire it started and idled fine
To No crank no start help reduced engine power
