Need help with Heater core replacement
Old Oct 17, 2023 | 11:26 AM
sonata2.0T's Avatar
sonata2.0T
Default Need help with Heater core replacement
Just my luck, I have a small leak in my heater core and can't stand the smell and it is finally getting cold in south west Florida. I have the service manual and watched the very few videos on YouTube, I know it will be a PIA but I'm willing to try. Since GM doesn't make any of the AC parts anymore I need a good source for the heater core and all the seals and gaskets or anything I can substitute for the original seals. I hate to do a half *** job and try to put things back together as close to original as possible. I need a quality heater core if anyone knows where to get one I don't want to have to do this job twice. Also, my daughter uses my second car for work and I don't want to driver her to work more than a couple of days so I would like to have every part I need before I start. Any help will be appreciated.
Old Oct 17, 2023 | 01:34 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Rock Auto is generally good. Did your local parts stores tell you they couldn't get any of the parts you'll need?
Old Oct 17, 2023 | 03:42 PM
redzg's Avatar
redzg
The C5 Parts Manual lists two different seal kits for the HVAC housing and blower. Kit #1, required when servicing the evap core is part # 52478813. Kit #2, required when servicing heater core, is part # 52478817. Both kits are listed as discontinued by GM, but I see that Topflight lists two apparently very similar kits, their Part #38364 listed as equivalent to the 52478813 kit, and then their Part #203973 -- NoT listed as equivalent to 52458813 or 52478817.
I thought Corvette Central and Ecklers both used to have seal kits, but CC doesn't list 1/10th of the parts they used to, and Ecklers apparently no longer handles C5 parts at all.
Old Oct 17, 2023 | 05:11 PM
sonata2.0T's Avatar
sonata2.0T
Thanks for the part numbers I found both looks like I probably need both kits.
Old Oct 17, 2023 | 08:37 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Cold in Cape Coral ??…LOL !!…I don’t know if Vette is your DD but I don’t think I’ve used my heater since living here…you can do a heater core bypass and be done with it if you don’t travel out of state where it’s colder…did you call Roger Dean ??
Old Oct 17, 2023 | 10:39 PM
sonata2.0T's Avatar
sonata2.0T
I took off the heater bypass when it started getting colder a couple of days ago and tried a leak sealer which didn't work. I hate cold weather.
Old Oct 18, 2023 | 08:14 AM
Simtech's Avatar
Simtech
Did my heater core as a "while I'm in there precaution" and tried to use a rock auto FOUR SEASONS 90055 heater core. The flange that goes through the ac box physically would not fit through the hole. I ordered UAC HT399418C from rock auto and it worked fine. I also had trouble with the A/C evaporator core from Rock auto FOUR SEASONS 54567. The seats for the seals were cut differently so they would not seal, I ended up using GM GENUINE 1562692 from rock auto and everything works good now. This project turned in to a cluster F**k but I got it done and everything works good now. Remember Rock Auto has no, I mean 0 customer service. You can send stuff back and reorder another part but it takes a lot longer and you have to pay return shipping. The car is my daily driver but I am fortunate enough to have extra toys.
Old Oct 18, 2023 | 09:19 AM
sonata2.0T's Avatar
sonata2.0T
Looking at the picture of the UAC HT399418C heater core the pipes are not even they are staggered, do the pipes rotate at the core connection? Did you replace the foam seals, the ones on the heater core look like they would disintegrate over time the ones around the evaporator look stronger. What did you seal the plastic case with?
Old Oct 18, 2023 | 11:12 AM
Simtech's Avatar
Simtech
I replaced the seals that came with the cores and re-used what I could. I did not order any seal kits and if I remember correctly most of the seals were in pretty good shape.
I don't remember about the pipes but they all lined up and worked well.
Old Oct 18, 2023 | 04:57 PM
grinder11's Avatar
grinder11
Man!!! This is a bummer, because I need a new evap core for my A/C. As long as I'm in there, and considering my car is going on 24 years old with 140,000 miles on it, I think it'd be stupid not to have the heater core replaced too. None of this sounds good to me! I hate to think I'm gonna throw 2,500.00+ into it, and still have issues afterward.......
Old Oct 18, 2023 | 06:54 PM
sonata2.0T's Avatar
sonata2.0T
I'm considering doing the evaporator too but hate to change out a good one. The first time I replaced an evaporator it leaked worse than the original, had to put the original back in while I waited for a replacement.
Old Oct 19, 2023 | 07:40 AM
Simtech's Avatar
Simtech
Haven't had any issues since the install. Things obviously did not fit or seal during the install. Once it was all together and working it has been great. I the south A/C is a must during the summer, and most of the year for that matter.
To Need help with Heater core replacement
