Shifting in the cold
Old Jan 23, 2003 | 10:18 AM
rev4679's Avatar
rev4679
Default Shifting in the cold
Posted this in general dis... so trying again here.
Wondering if anyone has had a similar experience. When I drive off in the morning, it seems that shifting the car is a little rough (6-speed). It's like the shifter doesn't want to go from 1-2, 2-3, or 3-4... It's hard to explain, there is more of a resistance going into gear, I guess it feels like the sychros aren't doing there job. But after a few miles.... she shifts smooth. Oh, and it's definitely more noticable the colder the weather is.
Any thoughts?
Old Jan 23, 2003 | 10:23 AM
dahoof's Avatar
dahoof
Default Re: Shifting in the cold (rev4679)
I had the same issue. I swapped my Tranny fluid to Redline Synthetic and have not had an issue since. Try That! It is a common thing though! :flag
Old Jan 23, 2003 | 10:29 AM
Silver Vert's Avatar
Silver Vert
Default Re: Shifting in the cold (dahoof)
i have that same problem, and i only have 8k on the car(considering there shouldn't be much "wear and tear" on the car). i'll try that. ;)
[Modified by Silver Vert, 10:30 AM 1/23/2003]
Old Jan 23, 2003 | 10:36 AM
rev4679's Avatar
rev4679
Default Re: Shifting in the cold (Silver Vert)
7000 miles here. and didn't notice it when i got the car, but it was much warmer then.
Dahoof, any tips on changing the fluid? or is it pretty straight forward. Also, is there a specific Redline product you used?
thanks!
Old Jan 23, 2003 | 10:39 AM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Cold fluid? I imagine it gets alittle more viscous the cold it is... Once it gets warm, however, it should be pretty easy...
Old Jan 23, 2003 | 11:25 AM
dahoof's Avatar
dahoof
The fluid change is super easy. Drain the old using the plug. And put the new stuff in using a fluid pump. Call Chris at speed demon Motorsports. He hooked me up with a great price and fast shipping.
:cheers:
Old Jan 23, 2003 | 12:58 PM
wwashing's Avatar
wwashing
thanks!
Use D4-ATF. Be sure and remove the fill-plug first. It'll drain faster, and you'll be sure you can refill it before you've drained the fluid out. :cheers:
Old Jan 23, 2003 | 01:05 PM
rev4679's Avatar
rev4679
Default Re: Shifting in the cold (wwashing)
Thanks for all the info..... guess this will be my first mod.
:cheers: to the forum.
Old Jan 23, 2003 | 01:17 PM
WildKarrde's Avatar
WildKarrde
From: My tolerance for stupidity is at an all time low.
Before you drive off, shift through the gears a few times. That can help warm it up and make it a little easier until you get the fluid changed.
Old Jan 23, 2003 | 01:44 PM
VetteDrmr's Avatar
VetteDrmr
It's definitely related to the ATF's viscosity when cold. As far as draining it is concerned, it usually comes out as a gusher when I pull the plug, and that's with the fill plug installed. Last thing I want is to have it come out faster!
Hope this helps,
Mike
Old Jan 24, 2003 | 08:29 AM
Roncor's Avatar
Roncor
Default Re: Shifting in the cold (VetteDrmr)
I just went through a little research on the subject of changing out the tranny fluid myself, although not for the same reason, but as your C-5 is under warranty, consider that before you make the change- :D http://forums.corvetteforum.com/zerothread?id=474454
[Modified by Roncor, 8:34 AM 1/24/2003]
Old Jan 24, 2003 | 01:55 PM
wwashing's Avatar
wwashing
Hope this helps,
Mike
No the last thing you want is to have trouble removing the fill plug after you've drained the tranny! :cheers:
Old Jan 24, 2003 | 02:00 PM
rev4679's Avatar
rev4679
Hope this helps,
Mike
yup makes sense.... I'm not a newbe to DIY's, but can I tell you how :mad i was when i saw one of those oil transfer pumps in an autopart store. All those times I putzed around with hoses and squeezing the bottle, when changing rear end fluid. mann that stuff stinks.
Old Jan 27, 2003 | 08:30 AM
VetteDrmr's Avatar
VetteDrmr
Got me on that one. :yesnod: :thumbs:
Have a good one,
Mike
To Shifting in the cold
