Code P1416 - Part 2
Old Jan 23, 2003 | 01:11 PM
WildKarrde's Avatar
WildKarrde
From: My tolerance for stupidity is at an all time low.
Default Code P1416 - Part 2
When the code P1416 first came up, I asked about it and got some good information:
http://forums.corvetteforum.com/zerothread?id=471226
Now I have a couple other questions. My check engine light first came on with this code on a very cold day. The check engine light is supposed to go out once the engine has had three cycles without throwing the code. As the weather got warmer over the next couple of days, the check engine light eventually went out for about a week. Yesterday, it got very cold again and the check engine light came back on due to this code P1416.
So what is the connection between the temperature and this code? Is this a major problem I should be concerned with? What would you recommend as my course of action?
:cheers:
Old Jan 24, 2003 | 10:24 AM
WildKarrde's Avatar
WildKarrde
Default Re: Code P1416 - Part 2 (WildKarrde)
TTT
