Air pressure question...........
Old Jan 23, 2003 | 02:31 PM
ghostmech's Avatar
ghostmech
Default Air pressure question...........
I know air pressure is affected by ambient temp. My question is should I compensate for ambient temp when checking/servicing my tires? I know from experience that aircraft use a base temp of 70 degrees for things like servicing tires, accumulators, ect. I assume 70 degrees would be the base for auto tires as well. so at 70 degrees my tires should be 30 psi. Is there a rule of thumb to to plus or minus pressure at higher or lower ambient temp.
:confused:
Old Jan 23, 2003 | 02:50 PM
Duck916's Avatar
Duck916
Default Re: Air pressure question........... (ghostmech)
The main thing is checking the pressure first thing in the morning before the car has been driven. Once you've driven even a mile or two, the tires have heated up significantly.
I suppose if you're in Fargo or Canada, you might want to go a little higher, like to 31 or so on a really cold morning (<0 degrees), but otherwise I wouldn't worry about it.
